joint 2 following error
12 years 11 months ago #41230 by garymcrobertpdx
The Compumotor S6 drive input specs are:
A minimum step pulse width of 200 ns at a 40% - 60% duty cycle.
The Dir spec states that the direction must be stable for 2 miliseconds
before the drive receives the first step pulse.
This dose seem like a long time perhaps this is a typo and they
ment ns not ms!
12 years 11 months ago #41233 by garymcrobertpdx
Assuming that the 2ms is a typo and it should have been 200ns
I have experimented by changed on XYZ&B axis the ini vars to.
dirsetup = 400
dirhold =400
steplen = 400
stepspace = 400
The drives seem to work OK with this since the homing process
appers to work correctly. How ever when I exicute a G2 to bore
a 0.312" hole I get the same axis 0 following error as before.
12 years 11 months ago #41236 by PCW
Replied by PCW on topic joint 2 following error
Did you check your latency?
poor latency can cause following errors.
Unfortunately the current driver is more sensitive
to latency than it should be.
Also you have (at least) 8 step generators enabled
are this many actually used?
Enabling more hardware than you need will make
the latency caused ferror more likely to happen
12 years 11 months ago #41237 by garymcrobertpdx
Yes checked the latency again, I get a base thread of 25709 ns
and a servo thread 26654 ns This is the same as it has been.
I am using a Mesa 5i25 and a 7i76 daughter board since I need six
stepgens I have selected the 7i76x2 firmware option this yeilds 10
stepgens.
I see them in the hal file loadrt hm2_pci config " stepgens=10"
due to hardware consiterations I am usnig stepgens 04 to 09
00 to 03 are not used. Is there a way to disable these with out
affecting the stepgens I am using
One other observation If I set the feed rate very slow 1.5 in/min the
G2 boring of the 0.312" hole with a 0.250 endmill works but at 15 in/min
fails. How ever when I use the 0.125 endmill to G2 bore a different hole
0.280" it works fine at 15 - 20 in/min feed
12 years 11 months ago #41239 by PCW
The driver has no way to select individual stepgens
so you do have 10 enabled which is likely part of the problem
I would try re-arranging your wiring so that you can get by with just 6 stepgens enabled
(even is this requires somewhat different firmware)
12 years 11 months ago #41240 by garymcrobertpdx
Is it possible to disable the upper 4 stepgens by modifying the hal file to
loadrt hm2_pci config " stepgens=6"
Time to create page: 0.094 seconds
