Have you checked that the scale is correct and that a g code move of say 10 results in a machine move of 10 units?what I don't get is that 320 should be the right setting for the SCALE value when running 16 micro steps and 200 steps per rev...
Is there anything under axis that limits the micro stepping that linuxcnc can generate ? Should all drivers have the same micro stepping or can it support a different micro stepping per driver ?
gaeldk wrote: Any input ? i really need to get this machine working tomorrow monday and it is so frustrating to see it work perfectly under stepconf wizzard and vibrate when used under axis...
Rick G wrote: Have you checked that the scale is correct and that a g code move of say 10 results in a machine move of 10 units?
andypugh wrote: Are you absolutely sure that you are starting the new config and not the old config?
