Plasma THC Corner Lock
9 years 11 months ago #82601 by EW_CNC
Replied by EW_CNC on topic Plasma THC Corner Lock
Echesortux and all others.
I made the changes as you advised and so far it is working.
Below is your translated message, wish I could read it without translating it.
Thanks for all the support!
Message:
Hello, I answer you in Spanish because it is my mother tongue, I will also ask you to translate this text so you can understand it correctly.
You have the same problem that I have.
Unfortunately the plasma.xml file that you and I have from the gnipsel.com/shop/plasma/plasma.xhtml page is not correct. The parameter vel-tol to tu you enter the value of the speed tolerance in the first spindbox probably has been modified or renamed in the thc.comp
The thc.comp that you must have installed uses velocity-tol and not vel-to, in order to enter the values ​​from the pyvcp you must change <halpin> vel-tol <halpin> to <halpin> velocity-tol <halpin>
With this you can change the value from the panel. You must also modify the numerical parameters so that the minimum is 1 and the maximum 100 being these a percentage of the speed
You will have something like this:
<Spinbox>
<Width> "5" </ width>
<Halpin> "velocity-tol" </ halpin>
<Min_> 1 </ min_>
<100> 100 </ max_>
<Resolution> 1 </ resolution>
<Initval> 20 </ initval>
<Format> "1.2f" </ format>
<Font> ( "Arial", 15) </ font>
</ Spinbox>
I hope you can translate it.
The following user(s) said Thank You: echesortux
9 years 11 months ago #82606 by Rick G
Replied by Rick G on topic Plasma THC Corner Lock
Glad to hear you have it working!
Rick G
Time to create page: 0.266 seconds
