Servo PID Tuning - can't clamp down on overshoot
9 years 10 months ago #84878 by SRDC
Just to make sure the acceleration wasn't a problem at all, we dropped the acceleration down to 3 in/s^2. Halscope screenshot is attached -- no real change. The initial lag is still around 0.002-0.003 inches.
It exactly matches the acceleration time period, and then jumps into position almost vertically. It's almost like something is holding the motors back during acceleration.
9 years 10 months ago #84879 by PCW
You might try increasing the drives velocity loop gain (increase till it oscillates then back off 20% or so)
while linuxCNCs P term is low to see if that helps the lag.
the fact that its unaffected by acceleration does suggest mechanical issues though
9 years 10 months ago #84882 by SRDC
Just tried increasing "speed loop gain adjustment volume." It did help a teeny bit. We increased it 2 'gradations.' On the 3rd gradation, it started buzzing as soon as the drive was enabled, so we backed it back down to 2 gradations.
Still not changing the basic problem.
What mechanical issues would you look at?
