HelloYou need at least two lines of numbers for a comp file (and preferably a lot more)
If you are only going to use a single value at one point then you might as well just use the BACKLASH entry.
" Points in between nominal values are interpolated between the two nominals."
I can't interpolate if the current commanded position is not between two positions in the comp file.
try:
0 0.10 -0.10
10 10.1000 9.9000
For example. (if this is an inch machine with 10 inches of travel, or a metric machine with 10mm of travel,,,)
