Error: Calling a remapped M6 toolchange from a remapped cycle
9 years 1 week ago #100583 by bevins
terans1085 wrote: I used it similar to you, as it also occurred to me that REMAP does not call the epilog when used with a pure python remap.
So far, the only way I could get around the readahead issue mentioned earlier is by using this code:
Warning: Spoiler!
This forces sync before each epilog, and I'm somewhat happy. However this also causes a curious "bug" in such a chain of events:
- I open part1.nc in axis
- I open part2.nc in axis
- I run part2.nc
- I manually stop part2.nc
- part1.nc is loaded back automatically. Titlebar shows part1.nc. Preview still shows part2.ngc
- Manually pressing CTRL-R or reload icon reloads part2.nc
So i'm wondering, if it is possible to come up with an "abort" script that reloads the proper gcode file.....
It loads part 1 only after you manually stop part 2? Thats bizarre behavour. I will check if mine does that.
Did you use the stock epilog and it runs ok using your M6 functions?
9 years 1 week ago #100585 by terans1085
No I run my epilog, but it is mostly copied from stock.
No, any file loads fine, but if I stop the machine in the middle of a run, it reloads the previously loaded file.
Time to create page: 0.054 seconds
