- Configuring LinuxCNC
- Advanced Configuration
- Questions on interfacing a MAHO Phillips 432/10 keyboard with mux_generic.
- RotarySMP
- Thank you received: 553
11 Dec 2017 18:41 - 11 Dec 2017 20:41 #102921
by RotarySMP
Questions on interfacing a MAHO Phillips 432/10 keyboard with mux_generic. was created by RotarySMP
I was discussing interfacing the MAHO / Phillips 432/10 keyboard into LinuxCNC with Jens from Germany, who has a 600E.
The keyboard's 69 keys (numbered 1-80 with gaps) are multiplexed out on a simple 8x10 matrix of 18 pins of a 25 pin D-Sub connector.
The two attached pdfs Blatt1 and Blatt2 go together.
Jens already surveyed the pinout, and it looks like this. The blue numbers are MAHO's assigned key numbers.
Q1/ Can mux_generic do a non-square matrix like 8x10?
Q2/ Is this correct syntax?
loadrt mux_generic config="bb80” # Load rt component MUX-Generic configuered for bit in, bit out with 80 pin
addf mux-gen.00 servo-thread
Then we create some placeholder signals for the 18 input pins to connect to...
Net key_pin_01 <= hm2_5i25.0.7i84.0.1.input-01
Net key_pin_02 <= hm2_5i25.0.7i84.0.1.input-02
Then those signals are connected to the mux_generic input pins. This is the bit I dont understand from the documentation and other threads on the topic.
Q3/ How do I code it to make the rows and column assignments of an 8x10 matrix. Is it with some clever binary code at the end of the ...sel-bit command?
Net key_pin_01 => mux-gen.00.sel-bit000
Net key_pin_02 => mux-gen.00.sel-bit001
The mux_generic output pins are then available to be connected to the required functions in LinuxCNC like this.
Q4/ Will those output pins be ...out.bit.00 through ...out.bit.79?
Q5/ Does the count start at top LHand go across then down, line by line?
Net mux-gen.00.out-bit.61 => gmoccapy.jog-x-minus
Net mux-gen.00.out-bit.70 => gmoccapy.jog-x-plus
Mark.
Mark.
Last edit: 11 Dec 2017 20:41 by RotarySMP.
- Thank you received: 4976
12 Dec 2017 01:53 - 12 Dec 2017 01:53 #102965
Replied by andypugh on topic Questions on interfacing a MAHO Phillips 432/10 keyboard with mux_generic.
I think that you might have more luck with matrix_kb
linuxcnc.org/docs/2.7/html/man/man9/matrix_kb.9.html
Last edit: 12 Dec 2017 01:53 by andypugh.
- RotarySMP
12 Dec 2017 07:04 #102978
by RotarySMP
Replied by RotarySMP on topic Questions on interfacing a MAHO Phillips 432/10 keyboard with mux_generic.
Darn. That looks a lot more like a solution. Thanks Andy.
Mark
Mark
- RotarySMP
12 Dec 2017 08:18 #102981
by RotarySMP
I started reading forum threads on matrix_kb. Andy you wrote in this thread:
forum.linuxcnc.org/24-hal-components/335...for-cnc-build#101260
The MAHO keyboard includes a combination of functional keys, which will correspond directly to HAL functions, but also keys such as the numerical keypad, which are used for user-space entry in the MDI.
The matrix of keys is rather mixed up, so you cant just spit out the line/column of user space input keys from the function keys and have two matrices. Show stopper?
Mark
...but can't be used to type into user-space text entry.
Mark
- Thank you received: 5240
12 Dec 2017 17:29 #103018
Replied by PCW on topic Questions on interfacing a MAHO Phillips 432/10 keyboard with mux_generic.
I suspect that could be done by having the matrix scanner hand off some (translated) keycodes to
a realtime FIFO comp that in turn forwards the buffered keystrokes to a userland
component that feeds them to uinput
12 Dec 2017 17:35 #103019
Someone else is asking for this in a different thread.
I did originally have keystroke-output in the matrix_kb component, but couldn't be sure that the kernel function calls were thread-safe.
12 Dec 2017 17:39 - 12 Dec 2017 17:45 #103021
I dont think they are, that's why i assumed the components feeding keystrokes to the OS
need to be separated into a real time part and a userland part (sort of like halsampler)
Last edit: 12 Dec 2017 17:45 by PCW. Reason: clarify
- ozzyrob
- Visitor
12 Dec 2017 23:05 #103045
by ozzyrob
Replied by ozzyrob on topic Questions on interfacing a MAHO Phillips 432/10 keyboard with mux_generic.
Would a module (teensy ++ 2.0 comes to mind) with the LUFA usb stack work ?
I've been playing around with a couple of atmega32u4 (Sparkfun Pro Micro, Arduino Micro clone, similar to Leonardo) and the LUFA usb stack for a simple pendant and a quick and dirty control panel.
Configure it for a USB keyboard for buttons that require keyboard input and joystick to be used with halinput or hidcomp to expose those buttons that you want as pins ? The one physical device would appear as two devices when enumerated.
12 Dec 2017 23:38 #103049
I think that's fine for keypad entries but really not optimum for things like jog buttons.
By real time keypad scanning and handing off the non-time critical keypad stuff to
a userland shim, you get both keystrokes and real time reaction to critical keys
- RotarySMP
13 Dec 2017 09:27 #103066
by RotarySMP
Thanks for your responses.
While there are nostalgic reasons to reused the Phillips/Maho keyboard, I am not wedded to it. Since there is no trivial way to interface both the Userspace and HAL function buttons at this time, I'll leave this topic for someone more committed to the MAHO interface. Actually those keyboards seem to all have worn out buttons, so I think I'll just mount mine on the wall as a momento
Gmoccapy seems really well thought out. I havent used it to mill yet, but like the interface design, even if it is a little too colourful for my taste.
Mark
Mark
