Unexpected realtime delay and genserkins
8 years 6 months ago #109297 by PCW
Hmm, maybe I didn't read as carefully as I should have, wouldn't be the first time...
Is this possibly only a problem with genserkins?
That is, if you make a dummy config with loadrt genserkins and all references to its pins commented out,
do you still have the same real time issues?
8 years 6 months ago #109299 by PCW
Another thing that might help isolate the issue is looking at these times
hm2_7i92.0.read.tmax
hm2_7i92.0.write.tmax
motion-command-handler.tmax
motion-controller.tmax
8 years 6 months ago #109301 by Cornflakes
I have problem when command G0 is running
There is no errror when homing
Dummy config brings nothing
8 years 6 months ago - 8 years 6 months ago #109302 by PCW
What version of LinuxCNC and how did you install LinuxCNC?
Also can you get those numbers I mentioned before and after the first G0?
An easy way to get the max times of all functions is this:
halcmd show param *.tmax
Last edit: 8 years 6 months ago by PCW.
8 years 6 months ago #109649 by andypugh
Coming late to this...
Note that tmax is in clocks, not nS.
Perhaps genserkins itself is getting stuck in an iteration loop and taking too long to compute a result?
8 years 6 months ago #109653 by Cornflakes
I think its possible
How can check it?
