2.8pre gantry racking
8 years 4 months ago #111933
Replied by andypugh on topic 2.8pre gantry racking
Try setting HOME_IS_SHARED
It is possible that the homing moves are starting before the other axes are off of the (shared) switch.
- llamatrails
- Topic Author
8 years 4 months ago #111942
by llamatrails
Replied by llamatrails on topic 2.8pre gantry racking
Yes the halmeter does show the pins changing state. All are FALSE and turn to TRUE when I trip them one by one.
I've also tried setting HOME_IS_SHARED both ways, 0 and 1 to no avail.
Z completes, the Y completes, both are at HOME which is not touching the micro switch. The gantry (X) will then head towards the switches, X0 will trip and back off, X1 will then head in, trip the switch and keep going as though it never found the switch.
My next move is to move the shared switches as they are on pins 11/12 of parallel port 0 to 11/12 of parallel port 1. I want to proof to myself that the wiring and ini/hal files are ok, maybe the G540 in the way somehow.
Rick
Rick
8 years 4 months ago #111950
Can I suggest using Halscope to watch the joint.N.home-sw-in pins, just to make completely sure that they are tripping during the actual sequence?
- llamatrails
- Topic Author
8 years 4 months ago #111952
by llamatrails
Yep, will do.
Rick
Rick
- llamatrails
- Topic Author
8 years 4 months ago #112025
by llamatrails
Well, the saga is over.
I moved the home switches to a second parallel port card so I could have enough pins for separate home switches instead of paralleling them. Same issue, the X axis would set one side and rack the other. Grrr. Halscope does show the joint.N.home-sw-in tripping as expected.
Since it made a difference before, I swapped the pins for the X joints in the hal file. Success !!! It now homes ZYXX as I want, and works repeatedly.
Why the pin swap makes a difference I don't know. Different parallel port, cable, BOB, individual wiring to the micro switches, all gave the same problem. After all this and finally getting a working system, I got an update notice for 2.8pre. May swap the pins back to see if the update does anything when I have some time.
Off to make parts again.
Thanks all,
Rick
Thanks all,
Rick
8 years 4 months ago #112028
I wouldn't expect the update to have any effect. I am pretty sure nothing much has changed there.
homing.c hasn't changed since february last year: github.com/LinuxCNC/linuxcnc/commits/mas.../emc/motion/homing.c
Can you show us the before and after versions of the code, perhaps it is in some way explicable?
llamatrails wrote: Why the pin swap makes a difference I don't know. Different parallel port, cable, BOB, individual wiring to the micro switches, all gave the same problem. After all this and finally getting a working system, I got an update notice for 2.8pre. May swap the pins back to see if the update does anything when I have some time.
Time to create page: 0.242 seconds
