setting up schaublin 125 cnc lathe with carousel toolchanger
6 years 1 week ago #186724 by inoxix
I checked github.com/LinuxCNC/linuxcnc/blob/2.8/sr...s/carousel.comp#L224 and found it does what I would expect but overlooked the usage below. Now it seams obvious.
I will do the change and test with Peter. If ok I create a PR for this fix.
BR
Tom
6 years 1 week ago #186731 by andypugh
The PR should be against 2.8 as this is a bug.
6 years 1 week ago - 6 years 1 week ago #186740 by trilobyte
tom sent me the compiled carousel.so and i replaced it on my computer. after a problem with the file permission it is now working!
big thanks guys!
Peter
Last edit: 6 years 1 week ago by trilobyte.
6 years 1 week ago #186748 by inoxix
The following user(s) said Thank You: trilobyte
6 years 1 week ago #186908 by jlviloria
dear, please, could you share the whole sequence of the tool change.
I still can't understand the carrousel component. How do you get the turret out? (Unclamped turret) I don't see any associated pin in what you post.
thanks
6 years 1 week ago - 6 years 1 week ago #186914 by trilobyte
The schaublin 125 toolchanger needs only two pneumatic signals. first the air for the valves etc is turned on, then the movement goes on as long as the second input is on. the movement itself is driven by a pneumatic mecanism.
here's a scematic how the carousel is wired in hal:
PDF
a Video from the chance sequence
if you'd like to see more pictures of the schaublin toolchanger here are picturse made during rework:
Pictures
peter
Time to create page: 0.405 seconds
