Hello,
I am trying to connect the original VFD that came with my milling machine to my 7i76e. Previously I borrowed my Huanyang VFD from my other mill to get things going, but the M100 has a somewhat different wiring requirement (
here's a link to the quick start / wiring
M100 Wiring Mode
7i76e Wiring Mode
If i connect ENA+ to PIN9, ENA- to PIN11 and short PIN9 & PIN12 or PIN9 & PIN13 it starts spinning forward/reverse.
I can't figure out how get a proper DIR+/DIR- connection to PIN12 & PIN13.
My last thought was using a relais, and wire NC=PIN12 (FOR), NO=PIN13 (REV) and use ENA- as COM.
I just don't know how to trigger the relais for either FOR or REV with DIR+ or DIR- then [it's late, i'm tired and i'm not an electronics expert
Anybody has a general idea for me on how to continue?
Thanks & best regards,
Pierre
