- Thank you received: 7
Copy. I don't know what either one means, but I'll edit the change as directed and look into it#spindle things
net spindle-cmd-rpm => stepgen.4.value
should be
net spindle-cmd-rpm => stepgen.4.velocity-cmd
This should be OK but will require some scaling...
Total luck, but I see what you mean there. Copynet spindle-on <= motion.spindle-on => stepgen.4.enable
Good stepgen disabled when spindle off
Almost certainly just a leftover dingleberry. I'll delete it.stepgen.4.velocity-cmd
leftover? not a valid hal statement
#setp stepgen.4.position-scale [AXIS_0]SCALE
you will need to set the scaling (unless scale of 1 is ok so Hz = RPM)
also this is not an axis so just use a number like
setp stepgen.4.position-scale 2.5
#2.5 Hz/RPM
haha. Well yeah, I doubt I'd be so lucky that the scale is 1.setp stepgen.4.maxaccel [AXIS_4]STEPGEN_MAXACCEL
This is not an axis so just use a number like:
setp stepgen.4.maxaccel 200
Copy. Deleted.net spindlestep <= stepgen.4.step
net spindledir <= stepgen.4.dir
net spindleenable axis.4.amp-enable-out => stepgen.4.enable
^^^^ delete this line
Vinito wrote:
Code:#spindle things net spindle-cmd-rpm => stepgen.3.velocity-cmd ... setp stepgen.3.position-scale 2
