- Configuring LinuxCNC
- Advanced Configuration
- MESA 7i96+7i76 : How to add 4 PWM and to connect 3 SSERIAL daughterboards ?
- nbremond
20 May 2019 20:02 #134396
by nbremond
MESA 7i96+7i76 : How to add 4 PWM and to connect 3 SSERIAL daughterboards ? was created by nbremond
Hello,
I'am building a versatile CNC+3D printing machine using some MESA boards to control it with LinuxCNC.
I have a 7i96 and a 7i76 connected on its P1 connector.
I also have a
- 7i73 (SSerial) for the pendant controller
- 7i83 (SSerial) for temperature measurement
- 7i87 (SSerial) for analog output
I'll have to add 4 PWM outputs to the 7i96 to control the heaters of the 3D printer. I guess it should be possible to add these PWM output by updating the bit file of the 7i96 FPGA. Is it correct ?
In addition there is only 2 SSerial connections (one on the 7i96, and one on the 7i76 board), and I'd like to connect the 3 SSerial daughterboards I have.
Do you thinks I could connect serveral SSerial daughter board on the same Serial connection ?
Or can I daisy-chain them ?
Thanks a lot for your help.
Best regards.
Bernard
I also have a
Best regards.
Bernard
20 May 2019 22:14 #134405
Replied by andypugh on topic MESA 7i96+7i76 : How to add 4 PWM and to connect 3 SSERIAL daughterboards ?
For a heater I think that software PWM driving GPIO would work fine.
But have you checked that the existing bitfile has no PWM channels?
(Mesaflash --readhmid would tell you)
The following user(s) said Thank You: nbremond
- nbremond
21 May 2019 06:20 #134445
by nbremond
Replied by nbremond on topic MESA 7i96+7i76 : How to add 4 PWM and to connect 3 SSERIAL daughterboards ?
Hello,
Thanks a lot andypugh for your reply. Software PWM is probably a good idea, much simplier. Do you have any link to instructions on how to setup this software PWM in linuxCNC ?
Concerning pre-build bitfiles, I have found a "5 steppers no PWM", and a "4 steppers and one PWM" options. But I need the 5 stepper and the PWM...
Yesterday, I was able successfuly setup the Xilinx FPGA ISE and manage to rebuild (regenerate the bitfile) one of the examples.
I think I'll have to use this tool to build the 7i96+7i76 bitfile I need (I was not able to find it in the prebuild bitfiles).
I'll run the Mesaflash --readhmid tonight.
Your help is very much appreciated.
Bernard
Bernard
- pl7i92
- Thank you received: 358
21 May 2019 06:33 #134448
by pl7i92
Replied by pl7i92 on topic MESA 7i96+7i76 : How to add 4 PWM and to connect 3 SSERIAL daughterboards ?
as the headers or not time critical
you may stay on software pwm to Gpio pins
that shoudt be fine for you
so no problem on that
- nbremond
21 May 2019 06:40 #134449
by nbremond
OK. I found the documentation for the software PWM. I think this is it:
www.linuxcnc.org/docs/html/man/man9/pwmgen.9.html
BTW, do you have any idea if I can connect 2 or more SSerial daughterboards on the same RS422/RS485 output of the 7i96 for example ?
21 May 2019 10:35 #134462
No, it is one sserial board per connector, they don't daisy-chain.
For extra smart-serial you would connect a 7i74 to the expansion header of the 7i96.
Unless you use a bitfile with PWM on that connector, of course.
For a heater I think you could get away with software PWM on smart-serial IO. Heaters are often controlled perfectly adequately with on-off control. I would use PDM rather than PWM in this case. (you get PDM by setting PWM frequency to zero)
- nbremond
21 May 2019 12:58 #134474
by nbremond
Hello,
To connect a 7i74 to add SSerial ports, I'll have to add a 7i92 (Ethernet FPGA board with 2 DB25 connectors) to my system.
Do you think the linuxCNC driver can manage several ethernet MESA boards ?
Do I ahve to duplicate the following line with a different IP address ?
Thanks a lot for the advise to go with PDM for heater control. It make sens !
loadrt hm2_eth board_ip=192.168.1.121Thanks a lot for the advise to go with PDM for heater control. It make sens !
- Thank you received: 5329
21 May 2019 13:21 #134475
Replied by PCW on topic MESA 7i96+7i76 : How to add 4 PWM and to connect 3 SSERIAL daughterboards ?
Yes, the driver supports up to 4 cards. You need to have 2 separate IP addresses (
10.10.10.10 and 10.10.10.11 would be good choices )
You also need to use the read-request function to avoid stacking the read functions
Ethernet response times, I think I have an example hal file with 4 devices i can post here later.
Unfortunately, when you have so much I/O it probably would have been better to start with a 7I76E or 7I80DB
Note that if you make your own bitfile for a 7I96, be careful the first time you write it
because a mistake can brick the card (requiring a JTAG restore)
One safe way to try new bitfiles is to write them to the fallback area:
mesaflash --device 7i96 --write my-new-bitfile.bit --fallback
and then reload the FPGA from the fallback area:
mesaflash --device 7i96 -- reload --fallback
Then if your new bitfile fails to work for some reason, you can recover by a power cycle
21 May 2019 13:52 #134479
Could one of the step/dir channels be re-purposed as smart-serial, with a custom bitfile?
21 May 2019 14:02 #134480
Yes, you could add up to 3 sserial channels to a 7I96 by using
differential step/dir outputs for RS-422 TX and differential encoder inputs
for RS-422 RX.
(with quite screwy wiring)
for RS-422 RX.
Time to create page: 0.108 seconds
