How to move joints of a new robot to verfiy it's motions?
7 years 1 month ago #145597 by andypugh
Is your robot a serial robot? Have you looked at Genserkins?
7 years 1 month ago #145606 by jaxonusa
For me, yes and no. Serial yes, I'm ignorant of Generkins
Is there a Generkins I can select from the configuration selector?
I ran across
forum.linuxcnc.org/38-general-linuxcnc-q...puma-geometry#140795
which leads to
github.com/deanforbes/Staubli_RX60L/blob...rg/Ross/staubli2.gif
It looks like they've got nice linear motions, but I can't quite make out what G-code is running.
7 years 1 month ago #145607 by andypugh
jaxonusa wrote: For me, yes and no. Serial yes, I'm ignorant of Generkins
sim-axis-Vismach-puma-puma560 uses genserkins.
The following user(s) said Thank You: jaxonusa
7 years 1 month ago #145622 by jaxonusa
sim-axis-Vismach-puma-puma560 is really neat. Help me understand.
G-code -> interpreter -> Genserkins -> hal pins ?
There's a trajectory planner in there somewhere too right? I'm really really terrible about figuring out the flow of information looking at github. Is there some kind of block diagram that shows how G-code turns into writing to a joint pin?
The abc. Is it a Euler sequence? 1st a about x, then b about y, then c about z? I've worked with kukas where a is the 1st rotation about z, then b about y, finally c about x.
7 years 1 month ago - 7 years 1 month ago #145626 by andypugh
jaxonusa wrote: sim-axis-Vismach-puma-puma560 is really neat.
I think in that sim you can switch between cartesian and joint jogging (Machine menu or $ shortcut). Which might answer one of your questions.
G-code -> interpreter -> TP -> TC -> kinematics -> HAL.
linuxcnc.org/docs/html/code/code-notes.html
It's something like that. I confess I have never needed to know as I don't own a robot.
I think it is actually something that is entirely determined by the kinematics file. That basically gets the XYZ ABC numbers directly, and transforms them in to joint angles, so the ABC can be interpreted in a number of ways.
linuxcnc.org/docs/2.8/html/motion/5-axis-kinematics.html
Last edit: 7 years 1 month ago by andypugh.
Time to create page: 0.081 seconds
