auto tool measurement working
7 years 1 month ago #145893 by j.clark91
Hello,
Running linuxcnc-2.7.14-wheezy.iso off the live cd downloaded from the website
File Name: my-mill.zip
File Size:9.02 KB
i am posting this to help people who are trying to get the machine to auto measure there tool after manual tool change, after many hours of searching and reading the wiki pages i found a post on a different site that i based my program on i cant find it again but ill post the link when i do.
my set up means i cant have tool holders as it is a cheap machine from ebay so no tool is the same height.
I am going to change the file slightly as when i type T0 M6 into mdi it still goes to measure which will update later on here once done but it still works just minor inconvenience for now.
onto the tool changer ;)
i have set my tool probe in the G59 datum in X,Y and Z so it can be easily moved around the table as needed depending on setup, to set the z i tool the nut off the spindle and jogged down until the probe pin turned true and set it from there.
I have done this because it is a constant and won't change with the nut on or tool in the spindle it will always change the z location of the tool probe.
when you call the tool with the M6 command the spindle will rise upto the top home location (safe place) and wait for you to change tool, once okay pressed it will move over to the G59 location and begin to measure the tool fast from that location. Then come up and measure again slowly to get a more accurate reading. The height in the tool table will be a plus number, this means you can use multiple work offsets in the program with each tool.
The ngc program DOES NOT change the machine back to G90 or to the datum used before tool change because the way i program
G0 G90 G53 Z0. (SAFE HIGHT)
T1 M6 (CALL TOOL)
M00 (STOP TO TURN SPINDLE ON MANUALY)
G0 G90 G54 X0. Y0. S1000 M3 (SAFE LINE, RESET TO G90 TURN SPINDLE ON AND MOVE TO LOCATION)
G43 H1 Z10. (TOOL COMP ON SAFE PLACE ABOVE WORK)
Z5.
(G CODE HERE)
G0 G90 Z10. M5 (UP TO SAFE LOCATION ABOVE WORK, SPINDLE OFF)
M01 (OPTIONAL STOP)
this way the program will always use the write datum and mode relevant to what you are going todo.
when setting the work datum i will use a wobbler to find the x and y location and set these in the work offset as required. when setting the z i will load up a tool (usually the 1st tool i am going to use) and measure it in mdi by calling up the tool number and m6, then once set and g43 active ill touch the tool on top of each workpiece as required by the setup.
with the G43 active it will be relevant to the G59 work offset z location, so when the next tool is measured it will return to the same location on the workpiece.
the code :)
this is the relevant code in the .ini file
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
SUBROUTINE_PATH = macros
REMAP=M6 modalgroup=6 ngc=tool-change
i have seen a lot of posts that seam to over complicate this with inputs and options that i don't really think is very necessary.
in the .hal file this is the relevant part
loadusr -W hal_manualtoolchange net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
now for the ngc file, i am going to change this so it is a lot more simple and easier to follow but for now it works,
i am planning on creating one big else if statement so it don't try and measure a tool that's not there.
O<tool-change> SUB ( Filename: tool-change.ngc ) (------------------------------- CONFIGURATION PARAMETERS ----------------------------------------------) #<_ProbeRetract> = 2.0 ( small distance to retract before approaching switch/touch-off plate second time ) #<_ProbeFeed1> = 500 ( feed rate for touching switch/touch-off plate first time ) #<_ProbeFeed2> = 10.0 ( feed rate for touching switch/touch-off plate second time ) #<_ProbeMinZ> = -500. ( max distance in z for probe routine. shortest tool should trip before this) #<_ProbeRetract> = 1 ( distance to retract before starting slow probe ) #<_tool> = #<_selected_tool> #<_Ztravel> = 82.067 ( distance between machine zero and touch off sensor ) #<_previous_tool> = #<_current_tool> ( sets previous tool variable ) (-------------------------------------------------------------------------------------------------------) O100 if [#<_task> EQ 0] ( only run the subroutine in milltask interpreter. **Critical** keep ) (debug, Task ist Null) O100 return [999] O100 endif G53 G0 G90 Z0. ( move to high z position ) o200 IF [ #<_tool> EQ 0 ] ( check if tool zero selected and end routine ) (MSG, No Tool Selected ) o200 ENDIF G49 ( turn off tool compensation ) G94 ( units per minute feed rate ) G40 ( turn off cutter compensation ) G90 ( use absolute mode ) G59 M6 ( run normal M6 operation ) O300 IF [ #<_tool> EQ #<_previous_tool> ] (debug, Tool in spindle no change required) O300 return [999] O300 ELSE G59 G0 G90 X0. Y0. G91 G0 G38.2 Z[#<_ProbeMinZ>] F[#<_ProbeFeed1>] G0 G91 Z2.0 G38.2 Z-2.5 F[#<_ProbeFeed2>] G90 #<_ToolZRef> = #5063 #<_ToolConv> = [#<_ToolZRef>*-1] #<_ToolOffset> = [#<_ZTravel> - #<_ToolConv>] G10 L1 P#<_tool> Z#<_ToolOffset> G53 G0 Z0 o300 ENDIF #<_previous_tool> = #<_tool> G43 O<tool-change> ENDSUB M2
i hope you followed that okay i've tried to keep it simple as possible so everyone can follow.
please let me know if i can rephrase it so its easier to understand :) ive also attached the whole config at its current state so you all can see
File Size:9.02 KB
7 years 1 month ago #145918 by pl7i92
thank you but it is individual as you searched your needs
some may find it good
others may need different
in general a good example
The following user(s) said Thank You: Dinuka_Shehan
  • REX299
  • New Member
  • New Member
5 years 2 months ago #217054 by REX299
Replied by REX299 on topic auto tool measurement working
Anyone can confim those stuff work under Linux 2.9pre?? I cant made it work on my machine :((
5 years 2 months ago #217439 by andypugh
It should work. Not that much has changed.
5 years 2 months ago #217752 by szatri
Hello, I have a problem with this tool measurement procedure (in total and with a few others). The program starts normally, the machine is based on limiters, and in MDI I will enter M6 t1. It shows me a message that I don't understand, I don't know where the problem is.
image missing https://www.cnc.info.pl/pics/bb7a8b329eac691242690374736f8833.jpeg
5 years 2 months ago #217928 by andypugh
Can you paste the [RS274NGC] section of your INI file?
Time to create page: 0.176 seconds
