Hi
This will be a pretty unusual request, so apologies if this seems strange.
Our application is not actually machining, we are using LCNC to drive a machine across a surface and our process is more akin to 3d printing.
I would like to use a single point laser to measure the distance from the "print head" to the surface, and then have the head move to preserve a set distance, by overriding the commanded position along our z axis by some small amount.
I am guessing this is unlikely to be something you would normally want in a CNC package, but can you suggest which LCNC software modules I might look into modifying to send an "on the fly" modifier to the commanded position, as well as if LCNC can accept sensor inputs? I know this is all a little vague, I am collecting ideas around how to do this at the moment so any suggestions are welcome!
Cheers
Ross
