Insufficient memory for signal/pin
8 years 2 months ago #116183 by andypugh
I think this is a different problem, but it would so no harm to follow the instructions in 5.1 here:
linuxcnc.org/docs/devel/html/code/buildi..._locked_memory_limit
8 years 2 months ago #116184 by dgarrett
# using git Run-in-place build for current 2.7 (at commit:37940e6) $ halrun halcmd: status HAL locking status: current lock value 0 (00) HAL_LOCK_NONE - nothing is locked HAL memory status used/total shared memory: 312/307200 ... $ grep -H HAL_SIZE hal_priv.h hal_priv.h:#define HAL_SIZE (75*4096) $ echo $((75*4096)) 307200 # edit hal_priv.h to increase HAL_SIZE $ git diff hal_priv.h -#define HAL_SIZE (75*4096) +#define HAL_SIZE (100*4096) # run make to incorporate change to hal_priv.h ... $ halrun halcmd: status HAL locking status: current lock value 0 (00) HAL_LOCK_NONE - nothing is locked HAL memory status used/total shared memory: 312/409600 ...
The following user(s) said Thank You: Nico2017
7 years 5 months ago - 7 years 5 months ago #134547 by Nico2017
just for the records, after modifying the define HAL_SIZE in linxucnc-dev/src/hal/hal_priv.h I did
for RIP modification only
cd src/
make clean
./autogen.sh
./configure
make -j4 ( j4=quad processor speed )
sudo make setuid.
For building debian package to make the update available everywhere
> cd linuxcnc-dev/debian
> ./configure uspace
> cd ..
> dpkg-buildpackage -b -uc
Then dpkg -i linuxcnc-uspace.. ..deb
Then dpkg -i linuxcnc-uspace-dev... .deb
This even keep your local config files installed before the re-installation on top of the new deb files.
This also does not affect any Ethercat component already installed and working with linuxcnc
Thanks a lot to @dgarrett for the instructions.
Nicolas
Last edit: 7 years 5 months ago by Nico2017. Reason: More precise answer
6 years 9 months ago #155471 by Nico2017
Hi all,
I am just wondering up to which value the HAL memory could be extended and if there is a way to work out this value. Not that I want to be on the maximum edge but I would like to know how far I am from this theoretical limit.
Has it got an impact on the realtime process and could it lead to memory bleeding if this value is set too high?
Thank you,
Nicolas
6 years 9 months ago #155515 by HalaszAttila
Hello,
it is a good question. I use a compiled Linuxcnc with
#define HAL_SIZE (200*4096) - config, without any problem. But the higher limit is interesting for me.
6 years 8 months ago - 6 years 8 months ago #156543 by Nico2017
I am also wondering while reading the hal_priv.h file about
/* IMPORTANT: If any of the structures in this file are changed, the
version code (HAL_VER) must be incremented, to ensure that
incompatible utilities, etc, aren't used to manipulate data in
shared memory
Does this mean we have to modify the HAL_VER when extending the HAL memory by modifying:
#define HAL_STACKSIZE 16384 /* realtime task stacksize */ #define HAL_SIZE (75*4096)
Thank you,
Nicolas
Last edit: 6 years 8 months ago by Nico2017.
