Stepgen Quadrature Hal and ini file setup
5 years 8 months ago #198939 by PCW
You have lots of margin in step frequency:
Currently at 8.33 IPS*13229.1662 you will have a
~ 110.200 KHZ square wave on both A and B.
This gives you your ~440 KHz step rate, since the
drive steps on all edges of A and B.
And yes, you can use encoder feedback simply by swappiing
hm2_7i92.0.encoder.NN.position
with
hm2_7i92.0.stepgen.NN.position-fb
and connecting
hm2_7i92.0.encoder.00.velocity
to pid.nn.feedback-deriv
Note that the PID tuning will be quite different
5 years 8 months ago - 5 years 8 months ago #198940 by PCW
STEPGEN_MAXVEL is unchanged when backlash is used
with
and connecting
Ack hit quote instead of edit sorry for the double post
Last edit: 5 years 8 months ago by PCW.
4 years 1 month ago #251902 by P1-Engineering
What would be the advantage of using Quadrature input over step+dir?.
I'm currently trying to decide what would be the best option. I have a set of delta A2L drives with mesa 716E+7I85 boards. Everything is wired up and now starting to put together the configuration.
In the future I want to make it a full-closed loop system by fitting the mill with scales. For now I will probably feedback the servo encoder output. Also want to use the home to index function if this is possible.
4 years 1 month ago - 4 years 1 month ago #251905 by PCW
Quadrature has the advantage of not needing step time settings
(they can all be set to say 50) and having possibly higher step rates.
(4x higher than step/dir at the same minimum pulse width)
That is, if a drive had a 1 usec minimum high and 1 usec minimum low
step pulse specification, that would limit the step rate to 500 KHz
with step and dir but quadrature could reach a 2 MHz step rate with
the same timings.
Last edit: 4 years 1 month ago by PCW.
The following user(s) said Thank You: P1-Engineering
4 years 1 month ago #251989 by P1-Engineering
Thanks!. Sounds like the better option when the drives are able to process a high steprate. The Delta A2 drives can go up to 4mhz I believe.
Time to create page: 0.304 seconds
