2-speed spindle configuration - help
5 years 7 months ago - 5 years 7 months ago #201203 by Jaro
Thank you Andy.
today I tried to break up your "gearchange.comp"
by
www.forum.linuxcnc.org/10-advanced-confi...-configuring?start=0
can you advise me on configuration.
I do not use hy_vfd (huanyang vfd).
what to replace:
loadusr -W hy_vfd -d /dev/ttyUSB0
net spindle-at-speed hy_vfd.spindle-at-speed
net machine.on.delayed hy_vfd.enable
net spindle-enable hy_vfd.spindle-on gearchange.0.spindle-on
net spindle-cw hy_vfd.spindle-forward
net spindle-ccw hy_vfd.spindle-reverse
well thank you
Jaro
Last edit: 5 years 7 months ago by Jaro.
5 years 7 months ago #201253 by andypugh
It's hard to say, as I have no idea what your spindle control pins are called. But use what you have.
5 years 7 months ago #201322 by Jaro
It's done
5 years 7 months ago #201338 by J Green
Hope "it's done" means you got the 2 speed transmission wording !
If so would you share your newer HAL an INI files ?
Thank's
5 years 7 months ago #201450 by Jaro
Yes , 2 speed transsmision is working nice.
File Name: schaublin_...3-08.ini
File Size:4.4 KB
File Name: schaublin_...3-08.hal
File Size:19.59 KB
The following user(s) said Thank You: J Green
5 years 7 months ago #201454 by J Green
Thank You very much
Glad you got it working . Your latest HAL an INI files will help many others in coming up with a solution a for 2 speed transmission . Saving the constantly reinventing of a wheel..
Bob
Time to create page: 0.374 seconds
