- Thank you received: 2181
cmorley wrote: ok good.
Can you post your latest config files again - I think you mentioned doing corrections.
If you have mutiple copies of your config make sure you are using the right one - most of us have been bit by that.
Otherwise I can't see why it doesn't work.
AcBCDN wrote: The distance between joint 1 trigger and joint 4 trigger is less than .5mm. I manually stepped want watch each trigger activate.
Negative on each? (I assume)
