Cannot use ethercat terminals sending more than 1 byte.
- Stormholt
- Thank you received: 8
04 Jun 2021 08:22 - 04 Jun 2021 11:19 #211133
by Stormholt
Cannot use ethercat terminals sending more than 1 byte. was created by Stormholt
Dear forum
I have been trying to use more ethercat terminals. A lot of them do not have drivers implemented for them. The ones i have that dont have drivers are EL2014, El3004, EL3202, EL3314. I have created the driver using the mighty Grotius forum.linuxcnc.org/27-driver-boards/3559...-how-to-installguide . The drivers work fine on their own, verified by using twincat in windows. The problems occur when the terminals are connected serially in the EK1100.
Lets say I have the terminals connected like this: Ek1100, EL2004(1byte of data), EL2014(4byte of data), EL1002(1byte of data), I will only receive 5 bytes. Additionally the EL1002 will have its hal values controlled by what the first terminal shows.
By testing with different terminals i have found the pattern to be: All devices after a device that sends more than 1 byte will not have its data sent/read, but rather show values based on the very first terminal. If i had a stack like this:EL2014(4byte of data), EL2004(1byte of data), EL1002(1byte of data) i would get 4 bytes, and like this: EL2004(1byte of data), EL1002(1byte of data), EL2014(4byte of data) i will get 6 bytes and every thing working fine.
All devices go into OP state and there are no error messages. I have looked a little in the linuxcnc-ethercat source code and inserted some print calls to see that the pdo_entry_count is correct, every slaves is iterated through, but the master process data length is not correct.
I suspect the drivers i have written to create some kind of issue, but i have stared myself blind trying to find the root of the problem.
Any help is appreciated! I have attached the drivers i have written
Last edit: 04 Jun 2021 11:19 by Stormholt.
- db1981
- Thank you received: 276
06 Jun 2021 17:30 #211310
by db1981
Replied by db1981 on topic Cannot use ethercat terminals sending more than 1 byte.
Hello Stormholt,
i have taken a few look on your code and can't see nothing what is obivousily wrong.
(its hard to look only at the code and to not be able to test it.....)
I would have seperated the channel data and build it to react dynamic on the channel count, to cover all el201X.
dmesg tells nothing? Did you set "ethercat debug 1" ?
- Grotius
- Thank you received: 2349
06 Jun 2021 20:18 - 06 Jun 2021 21:16 #211346
by Grotius
Replied by Grotius on topic Cannot use ethercat terminals sending more than 1 byte.
Hi Stormhold,
In file el2202.h there is a error. It misses the lcec.h include.
Maybe that will fix the rest in the compile sequence.
And a idea can be. Just compile the lcec.so lib with only the drivers you actually use. It this works oke. You know a little more.
attached a lcec.so and lcec.conf with only inside :
I hope this works.
To test in a stack like : EL2014(4byte of data), EL2004(1byte of data).
obj-m += lcec.o
lcec-objs := \
lcec_main.o \
lcec_class_enc.o \
lcec_generic.o \
lcec_el2xxx.o \
lcec_el2014.oI hope this works.
Last edit: 06 Jun 2021 21:16 by Grotius.
- Stormholt
08 Jun 2021 07:05 #211483
by Stormholt
Replied by Stormholt on topic Cannot use ethercat terminals sending more than 1 byte.
@db1981 yes indeed no info from dmesg have used both ethercat debug 1 and 2.
I will try with seperated channel data!
@Grotius: good spot! i will try compiling as you have specified!
Thank you both for you help on this!
- Stormholt
08 Jun 2021 07:31 #211484
by Stormholt
When modifying the Kbuild to only the device used, like your example, get an error :and after adding lcec_ax5200.o \ to the compile:
lcec: dlopen: /usr/lib/linuxcnc/modules/lcec.so: undefned symbol: lcec_ax5200_init lcec: dlopen: /usr/lib/linuxcnc/modules/lcec.so: undefned symbol: lcec_el1152_init Please Log in or Create an account to join the conversation.
- db1981
08 Jun 2021 08:22 #211487
by db1981
compiling only single modules in this way will not work..
you have to delete the unused driver data_types in lcec_conf.c and .h .
Did you add your types to lcec_conf? i forgot this to ask before...
- Grotius
08 Jun 2021 08:29 #211488
by Grotius
Hi Stormhold,
It looks like a run error.
Maybe add some include's to the lcec_main.c, and some lcec names + data over there. I did not do that.
Attached my qt project.
1. open -> qt-test.creator
2. edit config.mk (Set path to the halcomplie executable and lcnc main makefile)
3. edit configure.mk (Set path to the halcomplie executable).
4. edit qt-test.includes (Set path to several includes)
5. Cntr+r (run)
6. When compiled you get the lcec.so and lcec_conf.
7. When doing a new compile just delete the lcec.so and lcec_conf before. ( or do a make clean )
8. Warning's about "set an executable in the custom run configuration" are not important.
5. Cntr+r (run)
- Stormholt
08 Jun 2021 13:56 - 08 Jun 2021 13:59 #211507
by Stormholt
@db1981 i believe i add the drivers correctly, i have attached files i edit when adding new drivers
Furthermore, this i how i build after changes:
cd /home/linuxcnc-ethercat
sudo make clean
sudo make
sudo make install
sudo cp -f src/lcec_conf ~/vaerkscnc-dev/config/ #Same path as .ini
sudo cp -f src/lcec.so /usr/lib/linuxcnc/modules/
Last edit: 08 Jun 2021 13:59 by Stormholt.
- Stormholt
08 Jun 2021 15:01 #211514
by Stormholt
@Grotius i dont have/cant find similar paths for the include files:
May have something to do with linuxcnc being installed from apt.
The most similar i have are:
/usr/include/linuxcnc
/usr/lib/linuxcnc
/home/linuxcnc-ethercat/src
With which i get an error: :-1: error: You need to set an executable in the custom run configuration.
I have checked that the .mk files points to an executable halcompile
/usr/lib/linuxcnc
- Grotius
08 Jun 2021 15:48 - 08 Jun 2021 15:59 #211519
by Grotius
Hi Stormhold,
You are almost there ! Hold on.
This is no issue. Just look if Qt has compiled the lcec.so.
Qt gives this message because it expect's to start a executable like a program. But there is no. It's just a library.
I get the same message. I just check if lcec.so is compiled.
When for example i start a executable like a c++ hal program, you can set this in the build configuration.
I don't get the message. And the executable program
is then designed to load the lcec.so and then check the library values. Somewhere i did a example of that in a bash file.
You can start a simple bash file to check your library values. Like a bash file that does a halcommand with loadrt lcec.so
The most important includepath is that where halcompile lives. Mabye in c: $ sudo find . -name halcompile
This will problably be a /bin dir. For info, halcompile is a python program. So you could do a : $ python3 halcompile ...
May have something to do with linuxcnc being installed from apt..
Ah. If you have no dev version. You have to check your c: path for the spread around files.
That's why i suggested a lcnc install in opt/linuxcnc before. Andy is with me.
Last edit: 08 Jun 2021 15:59 by Grotius.
Time to create page: 1.015 seconds
