stdglue
5 years 2 months ago - 5 years 2 months ago #219071 by smplc
Replied by smplc on topic stdglue
Maybe AXIS lathe display has to be non-simulation for stdglue.py to run T.
Maybe remapped G-code is locating stdglue.py and doesn't have enough variables to run the cycle_prolog function. Most of my source code experience is C Programming, some C++ and JavaScript. Not very much Python experience but some practice and Python has some comparison to C++ and could be learned. No knowledge of LinuxCNC Python abstract functions and would require a description, however, starting at the beginning of the main program would be helpful but lengthy and exhaustive sharing other Python files. Breaking into the code would be efficient. As to start question if the cycle_prolog has any libraries, has prototypes been declared, are methods private or public, are functions local and are variables global, constant and initialized. Else could the lathe.ini miss some script or could the /configs/python file miss some additional files. I learned most of additional lathe.ini script, stdglue.py and toplevel.py files from LinuxCNC_Documentation.pdf and appended has much as recoverable yet.
Last edit: 5 years 2 months ago by smplc.
5 years 2 months ago #219111 by cmorley
Replied by cmorley on topic stdglue
So the error message (about tool change) changed?
first you said: 'finally pops bad exception'
Now you said 'tool 101 missing'
A missing tool is easy to fix: add tool 1 and tool 10001.
But why did the message change?
5 years 2 months ago #219116 by smplc
I just realized that it's because I put a temporary hash in front of the lathe.ini and REMAP=T line, turning.ngc included T0101, ran and error message. The hash has been removed. Just T1 is reading the offset table and if REMAP=T effect as mentioned earlier. Else still receive 'finally pops bad exception' when trying to run with T0101.
I tried T10001 and error message 'T100: tool entry not found' when trying to run.
Also, sometimes receive error message 'can't do that (EMC_TASK_PLAN_SYNCH) in auto mode with the interpreter idle' when opening turning.ngc at AXIS lathe display.
5 years 2 months ago - 5 years 2 months ago #219117 by cmorley
I said you need to _ADD_ tool 1 and tool 10001.
For wear offsets remap to work it looks for two tool numbers.
For instance, if you call for tool 101, It looks in the tool file for tool 1 and tool 10001 and combines the information.
Anyways that still doesn't fix the finally pops error.
try this in the remap file change the code:
except Exception, e:
print e
self.set_errormsg("T%d index_lathe_tool_with_wear: %s" % (int(words), e))
return INTERP_ERROR
to:
except:     return INTERP_ERROR
Chris
Last edit: 5 years 2 months ago by cmorley.
5 years 2 months ago #219123 by smplc
Are you suggesting replace t with words ?
I edited the foregoing code replacing character t with words, saved, ran and received same error. words might have to be a pointer if 't' is an element to iterate and search, however, received an error too. words might of been a string or characters cast to an integer.
5 years 2 months ago #219130 by smplc
I inserted the except: return INTERP_ERROR too. Both simultaneous or one or the other and still error message.
I'd require to study and gain more practice programming Python to put more time into studying def index_lathe_tool_with_wear function. stdglue.py and top of page appears a couple of import modules to pass parameters too.
I could probably make due with T1 and way it's functioning for now but would like it resolved near future.
The cycle_prolog would be nice error free. Convenient if modal enabled because such G90.3 is comparable to a Fanuc G90 and could be utile simply to rough straight passes or any other non-allocated G-code and geometry.
Time to create page: 0.260 seconds
