Advice needed: Custom gear switch component
5 years 3 weeks ago #222865 by Baderbahn
Leider einiges zu tun, die letzten Tage und keine Zeit gefunden, die Files zu von der Maschine zu ziehen.... kommt noch.
Sadly I had a lot to do during the last days... I'll upload the files within the next few days.
Wußte nicht, daß Du auch Deutscher bist :D
Die 2821 ist ja eine ganz späte FP4A. Meine ist von 81 - eine der ersten voll-CNC- Deckels - die mit dem "Eierkopf"
I didn't know, you're also german.
Your 2821 is a pretty late machine - mine is one of the first Deckel CNC machines from '81
regards,
Simon
P.S. Ich schreib Dir 'ne PN, wenn's i.O. ist. habe ein, zwei andere Dinge, die ich noch bzgl. LinuxCNC abklären muß. Auf Deutsch ist das schneller erklärt, als auf Englisch.
4 years 7 months ago #236712 by chili023
Hi, would it be possible to get the gearbox .comp. I have a FP4 that I am switching to Linux CNC and your skript would push me into the right direction.
Danke und Grüße
4 years 7 months ago #236935 by chris@cnc
The comp is already post number 3.
Copy and paste this script in a new file and named to gearswitch.comp
load the linuxcnc-dev packet
sudo apt-get install linuxcnc-dev
compile file
halcompile --compile gearswitch.comp
install file
halcompile --install gearswitch.comp
load new comp in your hal file
loadrt gearswitch addf gearschwitch servo-thread
now you should see all pins in halshow
The following user(s) said Thank You: chili023
4 years 7 months ago #237222 by db1981
Hello,
the functional comp file is attached in post 4.
don't take the content of post 3, this is with errors.
4 years 5 months ago - 4 years 5 months ago #241865 by gernoff
I would like to start a conversation about a gear select comp etc. for my Deckel FP5 machine. chili023 is it ok if I post your FP4 stuff in a new thread as a starting point for the project.
I am a complete beginner when it comes to any type programming.
The FP5 should be simpler since it only used 2 motors one for
High Neutral Low
and one for
Low Med High gear
Last edit: 4 years 5 months ago by gernoff. Reason: typos
4 years 5 months ago #241916 by chili023
Hi gernoff.
Sure post away. I can help you addapting Jin's comp to your FP5.
You just need to give me the datasheet wiring diagrams of your machine.
I attached my updated comp for my Deckel FP4. It is 95% done just needs some cleaning up.
A.
File Name: 220503_Deckel_FP4.zip
File Size:56.66 KB
Time to create page: 0.072 seconds
