Orient Spindle question
  • Pro_El
  • Pro_El's Avatar Topic Author
  • Premium Member
  • Premium Member
03 Nov 2021 11:16 - 03 Nov 2021 11:16 #225090 by Pro_El
Orient Spindle question was created by Pro_El
hello to all
I am trying to configure spindle orientation with the orient component. I am using LCNC 2.8 and make everything by manual for orient component. I need to now how can start orientation. When i put M19 in MDI nothing happened. My spindle have quadrature encoder 2500ppr and is running fine on spindle M3 SXX command. I enable orientation in hal and put orientation offset in ini file. now in manual it say that M19 should asserted spindle.N.orient in my case spindle.0.orient  . This pin doesn't go high state when i hit M19.
Can someone pointed me what am i doing wrong and how can i start M19 process.
This is hal config i put in hal
loadrt orient names=orient
loadrt pid names=orient-pid
net orient-angle spindle.0.orient-angle orient.angle
net orient-mode spindle.0.orient-mode orient.mode
net orient-enable spindle.0.orient orient.enable orient-pid.enable
net spindle-in-pos orient.is-oriented spindle.0.is-oriented
net spindle-pos encoder.position orient.position orient-pid.feedback
net orient-command orient.command orient-pid.command
Any help and guide is much welcome
Last edit: 03 Nov 2021 11:16 by Pro_El.
  • Pro_El
  • Premium Member
  • Premium Member
03 Nov 2021 14:39 #225109 by Pro_El
Replied by Pro_El on topic Orient Spindle question
i see one unusual thing that orient position did not update with spindle position. Should i make this connection between them and if i should how can i make this line in hal.
03 Nov 2021 23:57 #225167 by 0x2102
Replied by 0x2102 on topic Orient Spindle question
Here is a Spindle orient example config from Talla83.
I have been using this as my base config a few times now.
The spindle in running in speed mode during normal M3 / M4 etc and PID control with M19.
Some of the comments are in German but it might give you an idea of what needs to be connected.
talla83.homepage.t-online.de/linuxcnc/20181124_Spindel_5i25.zip
The following user(s) said Thank You: Pro_El
  • Pro_El
  • Premium Member
  • Premium Member
04 Nov 2021 21:39 #225275 by Pro_El
Thanks Markus for the help, i am learning now to work with orientation and keep you posted what have been done.
05 Nov 2021 00:50 #225319 by Michael
Replied by Michael on topic Orient Spindle question
I am also working on my spindle orientation and found out a simple m19 doesn't work. It worked fine with a full M19 R0 Q10 P0
I was unable to sets or setup any of those values in hal so that I could make a simple M19 work. Hope this helps.
  • Pro_El
  • Premium Member
  • Premium Member
06 Nov 2021 09:46 - 06 Nov 2021 09:49 #225482 by Pro_El
I tryed this hal example but it is not for me because is Step and Dir. I have PWM. Now i found on other with pwm generators. But it gives me alarm when i start LCNC that hm2_5i25.0.pwmgen.05.output pin not found. Now i think because this hal is old and i am working on 2.8 LCNC there have been changes with PWM and Analog output. My first problem is to change : setp hm2_5i25.0.pwmgen.05.output-type 1       to mach with 2.8
Can somebody help me how to edit this hal file so i can use with my 5i25 card and LCNC 2.8 with Buster.
# SPINDLE
setp hm2_5i25.0.encoder.05.counter-mode 0
setp hm2_5i25.0.encoder.05.filter 1
setp hm2_5i25.0.encoder.05.index-invert 0
setp hm2_5i25.0.encoder.05.index-mask 0
setp hm2_5i25.0.encoder.05.index-mask-invert 0
setp hm2_5i25.0.encoder.05.scale [SPINDLE_0]ENCODER_SCALE
setp hm2_5i25.0.pwmgen.05.scale [SPINDLE_0]OUTPUT_SCALE
loadrt limit2 names=spindle-ramp
loadrt near names=spindle-at-speed,spindle-at-pos
loadrt timedelay names=spindle-active-delay
loadrt orient names=spindle-orient
loadrt pid names=spindle-pid
loadrt mux2 names=spindle-pwm-switch
loadrt or2 count=0
loadrt not count=0
loadrt and2 count=0
loadrt offset count=0
addf spindle-ramp servo-thread
addf spindle-at-speed servo-thread
addf spindle-at-pos servo-thread
addf spindle-active-delay servo-thread
addf spindle-orient servo-thread
addf spindle-pid.do-pid-calcs servo-thread
addf spindle-pwm-switch servo-thread
addf or2.0 servo-thread
addf not.0 servo-thread
addf and2.0 servo-thread
addf offset.0.update-output servo-thread
setp spindle-pid.Pgain [SPINDLE_0]P
setp spindle-pid.Igain [SPINDLE_0]I
setp spindle-pid.Dgain [SPINDLE_0]D
setp spindle-pid.bias [SPINDLE_0]BIAS
setp spindle-pid.FF0 [SPINDLE_0]FF0
setp spindle-pid.FF1 [SPINDLE_0]FF1
setp spindle-pid.FF2 [SPINDLE_0]FF2
setp spindle-pid.deadband [SPINDLE_0]DEADBAND
setp spindle-pid.maxoutput [SPINDLE_0]MAX_OUTPUT
setp spindle-pid.error-previous-target true
setp spindle-ramp.maxv [SPINDLE_0]ACCELERATION
setp spindle-at-speed.difference [SPINDLE_0]MAX_ERROR
setp spindle-at-pos.difference 0.01
setp spindle-at-pos.in1 0
setp spindle-active-delay.on-delay 0
setp spindle-active-delay.off-delay [SPINDLE_0]OFF_DELAY
# orient mit motion verknuepfen
net orient-angle motion.spindle-orient-angle => spindle-orient.angle
net orient-mode motion.spindle-orient-mode => spindle-orient.mode
net orient-enable motion.spindle-orient => => and2.0.in1
# Position vom Encoder in den pid / orient und motion schieben
net spindle-pos => spindle-pid.feedback => spindle-orient.position
net spindle-pos <= motion.spindle-revs <= hm2_5i25.0.encoder.05.position
# Encodergeschwindigkeit U/sek in den near und motion schieben
net spindle-fb-rps motion.spindle-speed-in <= hm2_5i25.0.encoder.05.velocity => spindle-at-speed.in2
# Positionsvorgabe vom orient in den pid schieben
setp offset.0.offset 1
net spindle.otient-cmd spindle-orient.command => offset.0.in
net spindle-orient-cmd1 offset.0.out => spindle-pid.command
# Drehzahlvorgabe U/min aus motion in das limit2 schieben
net spindle-speed-rpm motion.spindle-speed-out => spindle-ramp.in
# Drehzahlvorgabe U/sek aus motion in das near schieben
net spindle-speed-rps motion.spindle-speed-out-rps => spindle-at-speed.in1
# Wenn Solldrehzahl gleich Istdrehzahl dann aus near das bit in motion schieben
net spindle-at-speed spindle-at-speed.out => motion.spindle-at-speed
# Wenn Sollpositon gleich Istpositon dann aus near das bit in motion schieben
net spindle-pos-err spindle-at-pos.in2 <= spindle-pid.error
net spindle-at-pos spindle-at-pos.out =>
net spindle-on0 motion.spindle-on => spindle-active-delay.in
net spindel-on1 spindle-active-delay.out => or2.0.in0 => not.0.in
net spindel-on2 and2.0.in0 <= not.0.out
# orient und pid aktivieren
net orient-active and2.0.out => or2.0.in1 => spindle-pwm-switch.sel
net orient-active => spindle-pid.enable => spindle-orient.enable
net spindle-enable or2.0.out => hm2_5i25.0.pwmgen.05.enable
# motion gibt Signal an Encoder das beim naechsten Z Signal auf 0 gestellt werden soll
net spindle-sync motion.spindle-index-enable => hm2_5i25.0.encoder.05.index-enable
sets spindle-sync 1
# pwm Signal entweder vom motion oder orient
net pwm-switch-in0 spindle-pwm-switch.in0 <= spindle-ramp.out
net pwm-switch-in1 spindle-pwm-switch.in1 <= spindle-pid.output
net pwm-switch-out spindle-pwm-switch.out => hm2_5i25.0.pwmgen.05.value
########## Bewegungsueberbrueckung um Schleppfehler zu vermeiden !!! ##########
net xpos-cmd axis.0.motor-pos-cmd => axis.0.motor-pos-fb
net ypos-cmd axis.1.motor-pos-cmd => axis.1.motor-pos-fb
net zpos-cmd axis.2.motor-pos-cmd => axis.2.motor-pos-fb
########## Bewegungsueberbrueckung ##########
net estop-out => iocontrol.0.emc-enable-in
This is part of the hal that need to change for my machine with LCNC 2.8 and 5i25 with 7i77 card
Last edit: 06 Nov 2021 09:49 by Pro_El.
08 Nov 2021 20:40 #225722 by 0x2102
Hello,
can you attach your working HAL prior to the spindle orient changes? Your basic HAL where you have M3 / M4 working.
  • Pro_El
  • Premium Member
  • Premium Member
09 Nov 2021 21:05 #225875 by Pro_El
Thank you a lot Markus for trying to help me.
 Here is my working hal file created with pncconf and linuxcnc 2.8
Thanks a lot again!
11 Nov 2021 22:39 #226156 by 0x2102
I will try to take a look over the weekend.
  • Pro_El
  • Premium Member
  • Premium Member
13 Nov 2021 22:57 #226380 by Pro_El
Thank you Markus for your help. I am lost with this ..
Time to create page: 0.436 seconds
