Probe screen v2 - malfunction?
- Marcodi
- Thank you received: 13
20 Dec 2021 23:41 - 20 Dec 2021 23:45 #229581
by Marcodi
Probe screen v2 - malfunction? was created by Marcodi
Hi everyone,
It's been a while I posted on the forum, thumbs up for linuxcnc as it works flawlessly.
Until.... I have the probe screen installed, fully functional, but I have crashed 2 probes now (they don't come cheap) so I want to ask how to resolve the reason why it happens.
Axis interface. Gladevcp . Tab probe screen.
So whenever you are inside of the probe screen and you use the keyboard numbers 2-8 4-6 and 3-9. The machine starts moving in the appropriate direction without stopping until it hits a limit switch. Meaning If you tap 9, the Z axis will move down and hopelessly crash and pulverize the probe. Or any other number will start moving sideways running the probe possibly in the fixtures, I had some close calles and some definite hits and to stop the movement nothing works except e-stop and hitting the opposite direction just makes the machine go the opposite way untill limit switch. Very frustrating.
I am so used to move the machine with keypad that it's second habbit to me and I forget to move out of the probe screen before I push the numbers, hence the crashing of probes.
So could anyone please guide me through a possible solution. Possibly disable the keypad while in probe screen for example and ideally how to get the xhc pendant working after a probe operation. Cause before probe operation xhc pendant works. After probe operation it doesn't so that makes it necessary to use the keypad with all unintended stupidities happening.
I hope someone can shed some light on this behaviour as it seems to me that I can't be the only one who crashes and burns our expensive probes this way. And I can not believe the designer intended for this kind of behaviour on a CNC machine.
Thanks for any help from the deepest pockets of my wallet
Last edit: 20 Dec 2021 23:45 by Marcodi.
- itsme
- Thank you received: 21
21 Dec 2021 18:34 #229640
by itsme
Replied by itsme on topic Probe screen v2 - malfunction?
I think my machine stops in any mode when the probe is accidentally triggered in a not probing move, but I will check...
How is your probe wired?
- Marcodi
21 Dec 2021 19:38 #229647
by Marcodi
Replied by Marcodi on topic Probe screen v2 - malfunction?
Well my probe is connected to my other z-height tools, it only has two wires so it is wired as an NC contact.
But the idea that if a probe gets triggered when not in active probe mode it would help. Although I doubt my machine would be able to come to such a sudden stop when z axis is moving down at 8000 feedrate without damaging the probe.
How did you set it to stop machine on accidental trigger?
- itsme
21 Dec 2021 19:45 #229648
by itsme
I also have it wired with my z-probe, but i think it is NO...
I just installed probe-screen-ng:
github.com/linuxcnc-probe-screen/probe-screen-ng
- Thank you received: 4648
21 Dec 2021 21:12 #229655
Try jogging then touch the probe tip by hand. You should see a message "probe tripped on non-probe move"
Back to the main issue, is the problem that normal keyboard jogging starts, but then does not stop when the key is released?
ie, are you seeing normal jog behaviour, or does it seem that Probe-Screen is itself reponding to key presses?
FWIW I would recommend simply not using the keyboard for jogging, it is much more reliable to use an MPG, preferably one hooked in to the realtime layers. (it, to the motion.... pins rather that halui.... )
Replied by andypugh on topic Probe screen v2 - malfunction?
I thought it was built-in behaviour.How did you set it to stop machine on accidental trigger?
- Marcodi
21 Dec 2021 23:54 #229681
by Marcodi
My mpg doesn't act after a probe action. Xhc pendant. Otherwise I would use that, but as that doesn't start working until I touch the keypad. This stupid actions happen.
Maybe it has been solved in more recent versions.
- Thank you received: 2173
22 Dec 2021 02:20 - 22 Dec 2021 02:22 #229690
Replied by cmorley on topic Probe screen v2 - malfunction?
There are specific times the a probe trip will and won't cause an error if tripped, unfortunately I forget the cafeteria.
It may be when feeding it will , when rapid-ing it won't
But your problem sounds related to the gladevcp panel rather then the probe.
Keystroke forwarding (from gladevcp to AXIS) has been a problem in the past.
Last edit: 22 Dec 2021 02:22 by cmorley.
- hIGGI
- Thank you received: 3
01 Feb 2022 19:28 #233734
by hIGGI
Replied by hIGGI on topic Probe screen v2 - malfunction?
Looks like i have same issue with crashing probe (and xhc pendant), maybe is it relevant (config for pendant interfering with config for probe)?
- CBollweg
- Visitor
11 Feb 2022 13:16 #234570
by CBollweg
Replied by CBollweg on topic Probe screen v2 - malfunction?
Hello, I have the same problem. When I move the handwheel and the probe trips, the mascine doesn't stop. I found a solution with MUX2 in an old wiki and am trying to find a solution with the motion.motion-type. Maybe someone has already done this?
Would be grateful for any help to avoid expensive mistakes in the future. Thanks in advance
Christian
Christian
- chrischan
04 Oct 2025 18:45 #335827
by chrischan
Replied by chrischan on topic Probe screen v2 - malfunction?
Hey guys
I have similar problem.
When hitting page up or page down button, the z axis starts moving until the end stops. And only stops moving if probe sensor is touched or esc button.
Why does the probe screen behaves that way?
is it possible to remove this function?
I started to read the different py files, but didn't find a clue to this problem.
Time to create page: 0.238 seconds
