Servo tuning f-error spikes
- Wieser
After decreasing the P and increasing FF1 (according to PCW in a perfect world that’s the only value that matters in velocity mode) i get a positive spike followed by a negative one.
With FF2 the positive spike gets smaller, but the negative spike increases.
I played around with all the other available values for two days now and can´t get those spikes any smaller. I even played with backlash although the machine has ball screws.
On Y and Z the tuning was pretty straight forward with no issues, following tommylights tutorial.
Only decreasing the acceleration of X to 100 or lower helped, but judging by feeling, the original acceleration of the Sinumerik controller is around 750.
I tuned all my axis at an acceleration of 500.
So with the tuning as in the second picture when I take a dry run of the axis splash screen, the X axis starts to oscillate during the arc moves. The arc moves G2/3 are also really slow (half to a quarter speed) compared to the G1 moves. I set the feedrate of the program to 4000 just for testing purposes. Also G64 P0.01.
Red is Y-f-error, white is X-f-error and purple is X-pid-output.
When I program a circle (R=2 or R=20) with G2 in MDI, the move is fast and without oscillation, so not 100% sure if it is related to the X axis tuning issue.
Any thoughts are greatly appreciated.
- aleksamc
- Thank you received: 67
Add an ini file to see your settings.
Also what parameters has servodrive? What interface is used to control servo?
- Thank you received: 1476
- Wieser
What do you mean with "interface to control the servo"?
The original control is a sinumerik 820M. Today I found a manual describing its parameters. Under axis specific bits I could find a Kv-parameter and a Multgain. For X and Y they are identical: Kv=3332 and Multgain=2700. But I do not really understand what they are.
I attached the pages from the manual, but they are in german...
Nothing about P, I, D or FF1, FF2.
While I was there I found the acceleration for the X axis: acc=1000 (so 500 should be possible)
Also I friend with an oscilloscope was here today, we measured the analog in to one of the axis, when the Sinumerik is connected.
I don’t know for sure, but this doesn´t look trapezoidal, maybe that’s a part of the problem. But maybe its only bad measuring?
For now (during the retrofit) I often swap between lcnc and the Sinumerik controller. I guess changing parameters on the drives would affect the performance of the Sinumerik? I made everything directly pluggable, so changing controls is a matter of 5 minutes.
- Wieser
When turning the motor pulleys of X and Y, I can’t feel any backlash. (Like you can on most manual machines)
Between X and Y, maybe X takes a little bit more force, but X is hanging of the saddle and Y is just sitting on top of the main casting...
I can’t think of a proper way to measure the backlash though.
Here is a picture with the machine and the mesa setup:
- OT-CNC
- Thank you received: 75
You can check backlash with a dial indicator measuring movement of the table for x.y or mount it in the spindle for checking the z. Apply a force manually to see if the needle deflects. You can also check for lost motion when stepping electronically with a small increment and see if it registers on the indicator when reversing.
Most likely not your issue here.
- aleksamc
As for interface - you control your servos with analog voltage reference as I understood.
I think you have big values of "P" parameters in ini file, try do decreese them.
- Wieser
Yes, that’s correct, the servos are controlled with 7i77 through +-10V. When the 10V output and the encoder input of X are disconnected, it slowly drifts. Only visible with dial indicator. Or if I wait some time then its visible by eye.As for interface - you control your servos with analog voltage reference as I understood.
P of X is 2, but with P=1 i get the same results. Should I decrease it even more?I think you have big values of "P" parameters in ini file, try do decreese them.
P of Y is at 6 and the Y axis f-error spike is below 0.01 mm.
Could maybe a loose head of the linear encoder cause such a problem? This just came to my mind. For the controller this would look the same as mechanical backlash.
I will check that tomorrow. The machine stands at a friend of mine, I sadly don´t have the space at home.
I tried pushing the X-axis by hand with an indicator on it, but I did this while the machine was on. No movement of the needle at all. I will try again tomorrow with the machine of.
- Thank you received: 7478
Loose P values will cause those spikes as the motor will react slowly to commands.
