wedm con ejes xyuv
4 years 5 months ago #242073 by Henk
Replied by Henk on topic wedm con ejes xyuv
I have a similar wedm machine that I started retrofitting but have not got to the point where I started playing with the u and v axes.
Basically, the u and v axes move relative to the bottom wire guide and that determines the angle between the wire and the xy plane. The angle is also affected by the distance between the upper and lower wire guides.
I think it would help to know how these machines were programmed originally.
For example, if you want to produce a cone shaped hole that is say 20mm in the bottom and 30mm Dia at the top, and the guides touch the work surfaces (not possible, but just to make the point) ....then the gcode would be something like this
Starting at x10 y0 and u5 v0
G3 i-15. (For xy)
But the u and v axis should then follow a similar circular path, but with a radius of 5. And I don't think it is possible to program that in one line,which I believe is the problem described above.
Maybe there is a simpler way?
BTW. How are you dealing with the spark generator?
G3 i-15
4 years 5 months ago #242079 by tommylight
Replied by tommylight on topic wedm con ejes xyuv
10 ?
Still waiting on eye candy ...
4 years 5 months ago #242166 by andypugh
Replied by andypugh on topic wedm con ejes xyuv
I think that the foam config probably can work.
You can treat XY and UV as independent, and use conventional G-code (possibly even from foam-cutting software)
Then, either use a custom kinematics which subtracts X from U and Y from V, or do exactly the same thing in the HAL layer.
If it was my machine I would experiment with which worked best in terms of homing (especially) and limit switches.
4 years 5 months ago #242257 by darito78
4 years 5 months ago #242259 by darito78
Replied by darito78 on topic wedm con ejes xyuv
this is the machine the foam function does not work for me because the movement commands of the u and v axes do not have to be equal to x and y in 2d cuts u and v do not have to move
4 years 5 months ago #242260 by darito78
That's exactly what I can't do. I don't know how to interact with the axes to make custom movements.
Time to create page: 0.061 seconds
