Z axis machine coordinate problem
3 years 10 months ago #259733 by Nest
Hi everyone... the machine work fine but if i use the G53 for go to the machine coordinates in the axi Z no work fine... the machine zero no is in the switch of axi Z, are more down... from the switch Z until machine zero there is 4,280 mm if we count the zero as 1 mm
if i want to move the axi Z at position machine -16.000 the axi no go to that position, the position end is -11.720
example:
this picture is when i setup the piece origin in the switch of Z axi
image missing https://i.imgur.com/o9LC67A.png
This picture is when y send the command G53 F100 Z -16
image missing https://i.imgur.com/R86iic6.png
Thia picture is when i setup the piece origin when the Z axi go to end of command G53
image missing https://i.imgur.com/Hty2it4.png
This picture is the .ini file
image missing https://i.imgur.com/e2tENeu.png
Someone can help my to fix this?
3 years 10 months ago #259734 by andypugh
Are you displaying "machine coordinates" or "relative coordinates"
The offset is 1mm and that is the difference between your G92 offset and the G54 offset.
G53 means "go to machine absolute postion" and then the relative position displayed will be that + G54 + G92, which is what you are seeing.
3 years 10 months ago #259744 by tommylight
3 years 10 months ago #259903 by andypugh
In the ini file, set home to 0 zero.
A non-zero home is quite normal, I don't think that is the problem here, it is combination of G54 and G92 offsets.
Time to create page: 1.064 seconds
