Question: P value with MESA Setup without encoders
3 years 6 months ago #268357 by PCW
It may be that there are timeouts in the card initialization section
of the driver that would need to be lengthened to solve this issue
3 years 6 months ago #268388 by 5G-antry
Yes, should be a problem of the initialization.
Those are not adaptable by the hm2_eth or hostmot2, if I get it right.
So the first idea with the code adjustment of the firmware (probably hm2_eth.c) could be the way to go?
3 years 6 months ago #268438 by PCW
Yes, the timeouts would be in the driver code
The following user(s) said Thank You: 5G-antry
3 years 6 months ago #268717 by 5G-antry
Ok Thank you.
Are there instructions or a tutorial regarding the creation of flashable bit-files.
I could not find sth in the git.
My plan would be to adapt the C-Code (that causes the timeouts), create a new bit file with all information needed for the Mesa 7i76E and flash it
... And hopefully do not brick the Mesa card :)
Maybe I will create a new thread.
By now this thread is rather off-topic
3 years 6 months ago - 3 years 6 months ago #268718 by PCW
The timeout code is in hm2_eth the driver (part of LinuxCNC)
there are no timeouts in the 7I76E firmware (other than the
settable watchdog timeout)
Last edit: 3 years 6 months ago by PCW.
3 years 6 months ago #268719 by 5G-antry
Ok.
Now I got it.
Had a understanding issue what is part of Mesa code and Driver code
Time to create page: 0.124 seconds
