ClearPATH servo with MESA 7i76e
3 years 2 weeks ago #283008 by Connor9220
For single ended wiring:
+5V -- > DRIVE STEP+ AND DIR+
7I76 STEP- --> DRIVE STEP-
7I76 DIR- --> DRIVE DIR-
On a 7I76/7I76E the 5V and 24V are isolated unless
the 24V common and 5V common connect externally.
That said, it probably does not matter because
If the enable has + and - inputs its fully isolated
so just needs its - input connected to 24V common
if you use a field output.
One disadvantage of using mixed 5V and 24V signals
is that a wiring mistake may damage 5V outputs.
Follow up questions.  I do have both 5v and 24v supply in the cabinet.  24v was simply going to handle the sensors and pneumatic relays, and the 5v was going to handle the case fans and supply v5 logic to the mesa.  Any benefit to this vs just doing all 24v?
Is there any GOOD reason to tie the enables to outputs vs just the 5v line?
3 years 2 weeks ago - 3 years 2 weeks ago #283262 by Teknic_Servo
Hi Connor,
I see a lot of your questions have already been answered, but I thought it would be helpful for me to weigh in as well (I’m an applications engineer at Teknic).
The choice between Step and Direction vs. quadrature is up to your personal preference and your controller’s capability. Step and direction is more popular, but quadrature has more noise immunity and other technical benefits. If your controller has quadrature capability, this is what we'd recommend.
As you read in the manual, we do not recommend 5V differential signals because they don’t always reliably swing the full five volts. A lot of manufacturers publish 5V, but the signals can drop as low as 2-3V.
Worse, there's a chance they may work at first, but then over time start to become unreliable (as the environment changes, the components age, if the motor changes temperature, etc.). Single-ended is a better option.
Regarding the enable line, we do not recommend hardwiring the enable for a couple of reasons. First, if the motor ever executes a protective shutdown (e.g., you accidentally ask for too much torque), toggling the enable line is the way to clear the shutdown and resume normal operation. The enable is also a safety feature that helps eliminate the risk of any surprising motion upon power-up. If the motor is powered up but disabled, it will not accept any move commands until the user deliberately enables it.
HLFB can be configured to give you various data. Many CNC operators use HLFB configured to provide “Servo On” or “In Range” to monitor any shutdowns or lagging (due to issues with mechanics, load, excessive friction, etc.). There is more information regarding the different configurations in the ClearPath User Manual (currently pages 50-60): teknic.com/downloads/
I’m not familiar enough with the controller you’re using to recommend specific wiring, but we’re happy to help with any questions about wiring if you would like to contact This email address is being protected from spambots. You need JavaScript enabled to view it. or fill out a contact request on our website: teknic.com/contact/
I hope this information is helpful. Please feel free to contact us with any additional questions that come up.
Best regards,
Bridgette O.  - Teknic Servo Systems Engineer
Last edit: 3 years 2 weeks ago by Teknic_Servo.
Time to create page: 0.312 seconds
