remap.cycle in 2.9.1 broken?
2 years 10 months ago #288223 by MaHa
Remap cycle worked perfectly in 2.8, also the example loaded fine. In version 2.9 i am not even able to load the example. In my config, its all setup, as it worked before, and it gives the same error as the example.
2 years 10 months ago #288230 by MaHa
Replied by MaHa on topic remap.cycle in 2.9.1 broken?
One problem found:  in   cycle.ini   of the example, the [PYTHON] stanza is missing with all the PATH_   entrys. Fixed that, but still it is not working
2 years 10 months ago - 2 years 10 months ago #288236 by Aciera
Replied by Aciera on topic remap.cycle in 2.9.1 broken?
I'm getting:
  File "/home/user/linuxcnc-2_9-oct/configs/sim/axis/remap/cycle/../../nc_files/remap_lib/python-stdglue/stdglue.py", line 361, in cycle_prolog
    if self.sticky_params[r.name] <= 0.0:
TypeError: '<=' not supported between instances of 'dict' and 'float'
[edit]
Changing line 361 in '/home/user/linuxcnc-2_9-oct/nc_files/remap_lib/python-stdglue.stdglue.py'
to
            if self.sticky_params[r.name]["r"] <= 0.0:
gives me this when I run the demo code, so I guess something is not quite right yet:
Last edit: 2 years 10 months ago by Aciera.
2 years 10 months ago #288239 by andypugh
I think the answer is to change the stdglue.py line 361 to:
else: if self.sticky_params[r.name]['r'] <= 0.0: return "%s: R word must be > 0 if used (%.4f)" % (r.name, words["r"])
(ie, append to index into the dict to find the float value.)
2 years 10 months ago #288240 by andypugh
Looks like we both came to the same conclusion.
Curiously, you can't run the G84.3 command from the MDI tab, but it works in G-code.
On a normal installation the strdglue.py file is found in /usr/share/linuxcnc/ncfiles/remap_lib/python_stdglue/
2 years 10 months ago - 2 years 10 months ago #288241 by Aciera
Not sure but it may be missing values that get set by G84.2 if it is run in the same gcode program.
[edit]
or maybe rather some kind of python context as it seems to be unable to find it
The following user(s) said Thank You: MaHa
Time to create page: 0.187 seconds
