Spindle speed limited
  • eduard
  • eduard's Avatar Topic Author
  • Premium Member
  • Premium Member
14 Jan 2024 07:35 #290636 by eduard
Spindle speed limited was created by eduard
Hello folks,
I have a spindle with max 60.000rpm. While using with 1000Hz VFD from the vfd software working on max rpm. The vdf is connected throuhg ethercat and I can control all the functions.
But the lcnc max rpm is 32766. In the ini file contains 10-60k rpm.
Where can I look for additional settings?
thx.
14 Jan 2024 07:41 #290638 by 0x2102
Replied by 0x2102 on topic Spindle speed limited
Post your spindle PID / spindle ini section.
14 Jan 2024 07:42 - 14 Jan 2024 10:53 #290639 by Calysto
Replied by Calysto on topic Spindle speed limited
Using rs485 or analogue signal?  Ethercat.
Last edit: 14 Jan 2024 10:53 by Calysto.
14 Jan 2024 07:58 #290641 by 0x2102
Seems like 6042 hex "target velocity" is 16Bit (2Byte).
That would give you -32768 to +32767 if you need forward and reverse spindle speed.
14 Jan 2024 08:25 #290646 by andypugh
Replied by andypugh on topic Spindle speed limited
Yes, that specific number immediately made me think of hitting the 16-bit integer limit.
You might need to command the motor frequency directly and convert in HAL, or possibly send the revs-per-second value from HAL and scale in the VFD.
  • eduard
  • Premium Member
  • Premium Member
14 Jan 2024 12:57 - 14 Jan 2024 13:02 #290690 by eduard
Replied by eduard on topic Spindle speed limited
Nice. Yes it is 16 bit.
"You might need to command the motor frequency directly and convert in HAL, or possibly send the revs-per-second value from HAL and scale in the VFD. "
I take a look at the VFD manual, but I think 0x6042 is in rpm. How can I command it diretly? You mean analog?
Last edit: 14 Jan 2024 13:02 by eduard.
14 Jan 2024 13:02 #290692 by 0x2102
Your XML doesn't matter. If you look at the manual it states that OD 6042h is 16Bit only.
  • eduard
  • Premium Member
  • Premium Member
14 Jan 2024 13:26 - 14 Jan 2024 13:26 #290696 by eduard
Yes, I did exatly that. I also look for rps, but nothing found.
What idea did you have for transforming in VFD? Writing a program for it, or with parameter?
Last edit: 14 Jan 2024 13:26 by eduard.
14 Jan 2024 15:27 - 14 Jan 2024 15:27 #290706 by 0x2102
Not sure if there is an option with the EtherCAT interface for your VFD. You might need to go back to analog 0-10V and start, stop and reverse inputs.
Last edit: 14 Jan 2024 15:27 by 0x2102.
  • eduard
  • Premium Member
  • Premium Member
15 Jan 2024 06:40 #290754 by eduard
Yes, I think going back to modbus. Maybe some ethercat modbus converter for beckhoff.
...If I did not get help from omron, maybe firmware update for ethercat hat.
