Mesa 7i96s firmware for Index (2.9 release)
2 years 2 months ago #307945 by vibram
Hello,
I'm looking for firmware for Mesa 7i96s with Index pin (release 2.9)
I followed Talla83 tutorial on Efinity but I have no clue how to implement the Index stuff.
Thanks a lot for your support
2 years 2 months ago - 2 years 2 months ago #307952 by PCW
All normal 7I96S firmware supports index on the encoder.
Did you mean stepgen index support?
Last edit: 2 years 2 months ago by PCW.
2 years 2 months ago #307957 by vibram
Yes exactly sorry, as I'm working on this, this is obvious but not for everybody
Stepgen index :)
2 years 2 months ago #307965 by PCW
If you want just one stepgen/encoder index on the 7I96s's built in encoder
interface, use 7i96s_esdi1.bin. If you need more, it depends on where
you want the index pins to connect. The 7i96sd_esdid.bin firmware
puts 3 stepgen index pins on the 7I96S encoder A,B,IDX inputs
(losing the encoder)
2 years 2 months ago #307986 by vibram
I absolutely need the encoder. However I only have 2 motors so is it possible to use the other axis step/dir instead? So pin tb1 14 and following?
Thank you
2 years 2 months ago #307987 by PCW
Step/dir pins are output only
So you need the spindle encoder and 2 step/dir indexes?
Time to create page: 0.161 seconds
