Mesa 7i96s firmware for Index (2.9 release)
2 years 2 months ago #307990 by vibram
Yes please
Is there a way to see how you do (screenshot or whatever) in order to learn a bit also?
2 years 2 months ago #308024 by PCW
Here is 7i96s firmware that adds a stepgen index pin for all stepgens
Note that these have been added to the P1 expansion connector
so can only be used with TTL/5V level index signals. It's also advisable
to add a say 220 Ohm series resistor to each input if interfacing
machine I/O to the P1 FPGA expansion port to protect against negative
input spikes.
File Name: 7i96ssdid_...8-17.zip
File Size:254.16 KB
The following user(s) said Thank You: rickjmain
2 years 2 months ago #308047 by vibram
Thanks a lot I will first check what you modified in order to understand and confirm no other impact on my setup and then flash the firmware
1 year 11 months ago #315682 by vibram
Thank you again.
I struggle with the configuration
If I understand well I need to adapt this line in my Hal file but can't figure what should I put?
net xindex-enable axis.0.index-enable <=> hm2_7i96s ???
I connected my index on i/o 36 (P1)
Thank you for your help
1 year 11 months ago #315700 by PCW
It connects to the hardware stepgen index pin
probably something like:
hm2_7i96s.0.stepgen.00.index-enable
halcmd show pin hm2 | grep index
 (when linuxcnc is running)
should list it
1 year 11 months ago #315716 by vibram
Here is the output of the command:
 38  bit   I/O         FALSE  hm2_7i96s.0.7i73.0.0.enc0.index-enable
    38  bit   I/O         FALSE  hm2_7i96s.0.7i73.0.0.enc1.index-enable
    38  bit   I/O         FALSE  hm2_7i96s.0.7i73.0.0.enc2.index-enable
    38  bit   I/O         FALSE  hm2_7i96s.0.7i73.0.0.enc3.index-enable
    38  bit   I/O         FALSE  hm2_7i96s.0.encoder.00.index-enable <=> spindle-index-enable
    38  bit   OUT         FALSE  hm2_7i96s.0.encoder.00.input-index
    38  bit   I/O         FALSE  hm2_7i96s.0.stepgen.00.index-enable
    38  bit   IN          FALSE  hm2_7i96s.0.stepgen.00.index-invert
    38  bit   I/O         FALSE  hm2_7i96s.0.stepgen.01.index-enable
    38  bit   IN          FALSE  hm2_7i96s.0.stepgen.01.index-invert
and the end of my readhmid
O Connections for P1 -> 7I96_2
Pin#                  I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir
P1-01/DB25-01          34   IOPort       StepGen          0        Index           (In)
P1-02/DB25-14          35   IOPort       StepGen          1        Index           (In)
P1-03/DB25-02          36   IOPort       StepGen          2        Index           (In)
P1-04/DB25-15          37   IOPort       StepGen          3        Index           (In)
P1-05/DB25-03          38   IOPort       StepGen          4        Index           (In)
I connected normal input on IO 34 qnd 35, it works fine. But how should I tell the system the stepgen index for axis X is on the 36 and for the axis z on the 37 ?
Time to create page: 0.410 seconds
