Remap of M6 not working correctly
1 year 11 months ago #314017 by Aciera
I am using remap/racktoolchange sample config as my starting point. It did work in simulation, but I do not get any movement when I edit ini file for axis/joints sections, add glade panels and my HAL files.
I see. Trying to edit a sim config to run physical hardware comes with a lot of potential pitfalls.
I would very much recommend to do this the other way around. Create a config that runs your hardware and then add the M6 remap to that.
1 year 11 months ago #314020 by viesturs.lacis
That was my first approach - I had a working config and I copied in all the bits of remap from a config of previous retrofit. But got all kinds of errors that ngc file not found although I could not find any mistake where subroutine folders are specified. I even copied from sample config and recreated the folders but still error. But in sample config it did work so I went the other route of merging my stuff into sample config
1 year 11 months ago #314022 by Aciera
can you post this config and the exact errors you are getting?
1 year 11 months ago - 1 year 11 months ago #314025 by viesturs.lacis
Config is in first post, starts with Biesse.ini
There are no errors, everything looks as if g-code file is being executed - I can pause, resume, execute next line, stop, you name it. But nothing actually happens. Running normal g-code files is ok, I have made quite a few test parts
Should I make a video of that?
Last edit: 1 year 11 months ago by viesturs.lacis.
1 year 11 months ago #314027 by Aciera
So if you have a tool-change (ie M6 T..) inside a gcode then the file executes all the way with the toolchange being ignored?
What I meant is post the first config you added the remap to and the errors you got there before you modified the sim config. The problem with the current situation is that nothing happens and there are no errors which makes troubleshooting very difficult.
1 year 11 months ago - 1 year 11 months ago #314029 by Aciera
I think you might be missing this in your hal file:
net tool-change iocontrol.0.tool-change iocontrol.0.tool-changed
[edit]
for troubleshooting it might also make sense to use the 'show halconfiguration' to watch the iocontrol.* pins like
iocontrol.0.tool-prepare
iocontrol.0.tool-prepared
[edit2]
Just so we are on the same page, I presume you have tried the suggested (ie reversed M6 T..):
T.. M6
Last edit: 1 year 11 months ago by Aciera.
The following user(s) said Thank You: viesturs.lacis
Time to create page: 0.446 seconds
