Is there a bug in the carousel component or am I doing it wrong ATC Denford
  • Adam Maszynotwór
  • Adam Maszynotwór's Avatar Topic Author
  • Senior Member
  • Senior Member
30 Apr 2025 09:10 - 30 Apr 2025 09:15 #327342 by Adam Maszynotwór
Hello, I'm starting to restore a lathe from scrap.
My problem is ATC (we'll get to the original ATC when I start the model)
Test model:
Step PIN8 dir PIN9 LPT stepper motor
Microstep 1600
4 pockets
1 gome sensor (pocket 1)
Head lock by left rotation (example video from the web)
Component linuxcnc.org/docs/html/man/man9/carousel.9.html
Basic lathe configuration
Symptoms:
T1M6 after starting linuxcnc looks for HOME and rewinds (strangely but it does rewind)
Each successive tool, e.g. T3M6, no longer rewinds
When I start from T2 M6 it passes HOME (activating it) but no longer rewinds while in position
My observations:
Dir changes but there is no movement. which means that there are no pulses flowing to PIN 8.
M66 waits for READY signal even though nothing is happening. Only after time has elapsed does the DIR state change and then it is READY
all files below
As you know I am not strong in HAL and in English please write as if to a child
O<changetool> sub
(debug, Tool change to T#<_selected_tool>)
M68 E0 Q#<_selected_tool>  ; Wybierz kieszeń
M64 P0                     ; Włącz karuzelę
G4 P2
; Czekaj max 15s na ready (z timeoutem)
M66 P0 L3 Q15
; Jeśli timeout, zatrzymaj karuzelę i zgłoś błąd
O100 if [#5399 EQ 0] (if timeout)
  M65 P0
  (msg, Toolchange FAILED - Timeout)
  M99
O100 endif
M65 P0                     ; Wyłącz karuzelę
(debug, Tool change OK)
O<changetool> endsub
M2
[code][code]loadrt stepgen step_type=0,0,0
loadrt carousel pockets=4 encoding=counts dir=1 num_sense=1
addf carousel.0 servo-thread
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 35000
setp stepgen.2.dirsetup 35000
setp stepgen.2.maxvel 100
setp stepgen.2.maxaccel 150
setp stepgen.2.position-scale 1
net astep stepgen.2.step => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
#net adir stepgen.2.dir => parport.0.pin-09-out
net adir carousel.0.motor-rev => parport.0.pin-09-out
#Konfiguracja carousel
setp carousel.0.scale 400
setp carousel.0.width 10
setp carousel.0.fwd-dc 10
setp carousel.0.rev-dc 100
setp carousel.0.rev-pulse 10
#Połączenie carousel z stepgen
net carousel-pos-cmd carousel.0.counts-target => stepgen.2.position-cmd
net carousel-counts carousel.0.counts <= stepgen.2.counts
net carousel-ready carousel.0.ready => iocontrol.0.tool-changed motion.digital-in-00
#net carousel-dir stepgen.2.dir <= carousel.0.motor-rev
net carousel-enable carousel.0.enable <= motion.digital-out-00
net carousel-enable stepgen.2.enable <= motion.digital-out-00
net carousel-pocket carousel.0.pocket-number <= iocontrol.0.tool-prep-number
net home-signal carousel.0.sense-0 <= parport.0.pin-10-in
#Toolchange
all files below
[/code][/code]
Last edit: 30 Apr 2025 09:15 by Adam Maszynotwór.
  • Adam Maszynotwór
  • Senior Member
  • Senior Member
30 Apr 2025 11:42 #327369 by Adam Maszynotwór
I'm not good at typical programming languages. I'm best at G-code.
Here, G4 has to be because after reaching the pocket, the READY pin is active so the toolchange procedure runs without moving the engine
Yes, I know that ATC is not a priority, but I'm asking in advance (I'll eventually write ATC on CL .. I think that thanks to the knowledge I've gained from trying to start CAROUSEL, I'll manage, and if not, I'll treat it as an axis and use g-code)
This machine is a challenge because:
I've never used a tool magazine
I've never done anything on servos
I didn't have a Mesa card either
and here it will be all
GUI AXIS
  • Adam Maszynotwór
  • Senior Member
  • Senior Member
30 Apr 2025 17:09 #327391 by Adam Maszynotwór
I have a few observations:
no pulses are generated for reverse movement when the magazine turns in one direction the stepgen.2.position-cmd value changes by 400 then stepgen.2.position-fb and carousel.0.counts tend to this value. when the moment comes for reverse movement nothing changes in the three above parameters. despite the fact that the Dir pin changes there are no pulses - so for some reason the carousel component does not add pulses resulting from the set carousel reversing time. N .rev-pulse .
I do not know how the mechanism should work the instruction says carousel.N.rev-pulse float in
The duration in seconds for which a ratchet changer (Boxford, Emco) should pulse the reverse pin to lock the holder.
on logic so pulses in an indefinite number for a specified time possibly some mathematics could calculate that if someone wants the reversing to last 5 sec. and the pulse frequency is known, stepgen.2.position-cmd should be increased by the result of these calculations and the pulsation command should be issued.
30 Apr 2025 19:28 #327398 by PCW
I know nothing about the carousel component but should that be dir=2 ?
  • Adam Maszynotwór
  • Senior Member
  • Senior Member
01 May 2025 06:05 #327412 by Adam Maszynotwór
dir=2 is for a revolver of this type
i.e. working in two directions and blocked mechanically or in a way other than changing the direction of rotation. generally dir=2 works. if I set it, the magazine rotates in two directions and looks for the shortest path to the tool.
by the way, I will add a fragment of the analysis that GROK did based on github.com/LinuxCNC/linuxcnc/blob/v2.9.2...onents/carousel.comp
  • Adam Maszynotwór
  • Senior Member
  • Senior Member
01 May 2025 06:11 - 01 May 2025 06:13 #327413 by Adam Maszynotwór
Below is the translated and polished version of your analysis, ready to be posted on the LinuxCNC forum. It retains all the technical details, observations, and context while being concise and clear for the community. I've formatted it to fit a typical forum post structure, focusing on your issue with the carousel component and the lack of reverse motion in REV_TIME.Forum Post: Lack of Reverse Motion in carousel Component (counts Mode, rev-pulse)Title: No Reverse Motion in carousel Component with counts Mode and rev-pulseBody:Hello everyone,Thank you for the help so far. I'm working on a toolchanger carousel with 8 pockets, driven by a stepper motor (1600 steps/rev, scale=200) in LinuxCNC (version [insert your version, e.g., 2.9.2]). I'm using the carousel component in counts mode (encoding=counts, dir=1) with a physical homing sensor on parport.0.pin-10-in. Homing works correctly, but subsequent M6 tool changes fail to perform the reverse motion (rev-pulse=2.0), even though carousel.0.motor-rev changes state. Below, I've analyzed the carousel component's source code to understand how the reverse motion (for locking) should work and why it’s not generating pulses on parport.0.pin-08-out in REV_TIME with stepgen in position mode (step_type=0).Analysis of Reverse Motion Mechanism1. Documentation on rev-pulseFrom the carousel component documentation:text
Copy
pin in float rev-pulse """The duration in seconds for which a ratchet changer (Boxford, Emco) should pulse the reverse pin to lock the holder""";
text
Copy
For tool changers which lock the carousel against a stop the \fBrev-pulse\fR pin can be set to a non-zero value. The motor-rev pin will then be set for this many seconds at the completion of the tool search and at the same time the reverse duty/cycle velocity value will be sent to the motor-vel pin.
Interpretation:
  • rev-pulse defines the duration (in seconds) that the motor-rev pin is active (TRUE) to perform a reverse motion to lock the carousel (e.g., for ratchet-type changers like Boxford or Emco).
  • During this time, motor-vel is set to rev-dc (reverse velocity), suggesting the reverse motion is intended for velocity control (e.g., DC motors or stepgen in velocity mode).
  • The documentation does not mention updating counts-target in REV_TIME, which is critical for counts mode with stepgen in position mode.
My Configuration:
  • carousel.0.rev-pulse=2.0 (2 seconds of reverse motion).
  • carousel.0.rev-dc=-0.5 (reverse velocity, 50% of max velocity).
  • stepgen.2.maxvel=80 (80 pulses/second).
  • encoding=counts, dir=1 (unidirectional carousel).
  • stepgen.2 in position mode (step_type=0), driven by carousel.0.counts-target.
Expectation:
  • After reaching the target pocket (e.g., T1 M6), the carousel should perform a reverse motion for 2 seconds, generating pulses on parport.0.pin-08-out (e.g., 80 pulses, calculated as 2.0 * 80 * 0.5).
2. Source Code Analysis – How Reverse Motion is ImplementedI analyzed the carousel.comp source code to understand how reverse motion is handled, focusing on the REV_TIME state.Transition to REV_TIMEReverse motion is initiated in the MOVE state (state 2) when the carousel reaches the target pocket (current_position == mod_pocket):c
Copy
case 2: // moving if ((current_position != mod_pocket) && enable){ deb = debounce; return; } else if (deb-- > 0) { return; } if (rev_pulse > 0){ motor_fwd = 0; motor_rev = 1; motor_vel = rev_dc; timer = rev_pulse; state = 3; } else if (decel_time > 0) { // stop and prepare for alignment motor_vel = 0; timer = decel_time; state = 5; } else { motor_fwd = 0; motor_rev = 0; motor_vel = hold_dc; active = 0; if (enable && current_position == mod_pocket) ready = 1; state = 9; } break;
What happens:
  • If rev_pulse > 0 (in my case, 2.0), the component:
    • Sets motor-fwd=0, motor-rev=1 (activates reverse direction, seen on parport.0.pin-09-out).
    • Sets motor-vel=rev-dc (in my case, -0.5 for reverse velocity).
    • Initializes the timer to rev-pulse (2.0 seconds).
    • Transitions to REV_TIME (state 3).
  • Key Issue: It does not update counts-target, which drives stepgen.2.position-cmd in position mode.
REV_TIME StateThe REV_TIME state (state 3) handles the reverse motion:c
Copy
case 3: // timed reverse pulse timer -= fperiod; if (timer > 0) return; state = 9; motor_fwd = 0; motor_rev = 0; motor_vel = hold_dc; active = 0; if (enable) ready = 1; break;
What happens:
  • The timer counts down rev-pulse (2.0 seconds) in thread cycles (fperiod, typically 1 ms in the servo thread).
  • During this time, motor-rev=1 and motor-vel=rev-dc (set in the MOVE state) remain active.
  • When the timer expires (timer <= 0):
    • Motion stops: motor-fwd=0, motor-rev=0, motor-vel=hold-dc (likely 0 in my case).
    • Sets active=0 and ready=1 (signals tool change completion).
    • Transitions to WAIT_ENABLE_FALSE (state 9).
  • Key Issue: There is no update to counts-target in REV_TIME, so stepgen.2 in position mode does not receive a new target position, resulting in no pulses on parport.0.pin-08-out.
counts Mode and Position HandlingIn counts mode (inst_code='C'), the position is calculated based on counts from stepgen.2.counts:c
Copy
case 'C': // encoder or stepgen counts. new_pos = current_position; if (homed){ int c; int t; int w = width / 2; c = (counts - base_counts); t = floor(((float)c + w) / scale); if (c >= (t * scale - w) && c <= (t * scale + w)) { new_pos = 1 + (t % inst_pockets); if (new_pos < 1) new_pos += inst_pockets; } align_pin = (c % scale <= 2 && c % scale >= -2); }
  • counts-target is updated in the DIR_CHOOSE state (state 1) for forward motion:
    c
    Copy
    counts_target += (mod_pocket - current_position) * scale;
  • In REV_TIME, counts-target remains unchanged, so stepgen.2.position-cmd equals stepgen.2.position-fb, resulting in no pulses.
Velocity vs. Position Mode
  • The documentation suggests motor-vel and motor-rev are primarily for velocity control (e.g., DC motors or stepgen in velocity mode, step_type=1).
  • In my setup, stepgen.2 is in position mode (step_type=0), where motion depends on the difference between position-cmd and position-fb, and motor-vel is ignored.
  • This explains why motor-rev=1 and motor-vel=-0.5 do not generate pulses – stepgen.2 waits for a change in position-cmd (i.e., carousel.0.counts-target).
3. Expected Behavior of Reverse MotionBased on the code and documentation, the reverse motion (rev-pulse) is designed as:
  • A timed reverse pulse: After reaching the pocket, the component sets motor-rev=1 and motor-vel=rev-dc for rev-pulse seconds (2.0 seconds).
  • Intended for ratchet-type changers where reverse motion locks the carousel against a mechanical stop (e.g., a pawl).
  • Assumes motion control via motor-vel and motor-rev, suitable for:
    • DC motors (with PWM).
    • stepgen in velocity mode (velocity-cmd).
    • Carousels with position sensors where the exact number of pulses is not critical.
  • In counts mode with stepgen in position mode, reverse motion does not occur because counts-target is not updated in REV_TIME.
4. Why It Fails in My SetupMy observations confirm the issue:
  • carousel.0.motor-rev changes to TRUE, and carousel.0.motor-vel to -0.5 in REV_TIME.
  • However, stepgen.2.position-cmd, stepgen.2.position-fb, and carousel.0.counts remain unchanged.
  • No pulses are generated on parport.0.pin-08-out because stepgen.2 in position mode does not receive a new position-cmd value.
Questions for the Community
  1. Is the carousel component in counts mode supposed to update counts-target in REV_TIME to enable reverse motion in position mode? If not, how should reverse motion be configured?
  2. Has anyone used the carousel component in counts mode with rev-pulse for a stepper-driven carousel? If so, could you share your configuration?
  3. Would modifying the carousel component to update counts-target in REV_TIME (e.g., based on rev-pulse, rev-dc, and maxvel) be a reasonable solution, or is there a better approach?
Last edit: 01 May 2025 06:13 by Adam Maszynotwór.
01 May 2025 07:14 - 02 May 2025 23:55 #327420 by Aciera
Looking at these sections in 'carousel.comp' makes met think that the reverse action does not work in 'counts' mode :
if (rev_pulse > 0){
motor_fwd = 0;
motor_rev = 1;
motor_vel = rev_dc;
timer = rev_pulse;
state = 3;
[snip]
timer -= fperiod;
Note that there is nothing changing 'counts_target'.
Last edit: 02 May 2025 23:55 by Aciera.
01 May 2025 07:19 - 01 May 2025 07:29 #327421 by Aciera
I once helped a user who needed to get a ATC turret working that used a stepper and needed to lock the tool by rotating backwards against a pawl (which I _think_ is what yours does):
To get this working we modified a component called 'toolchanger'. The final version is attached here:
forum.linuxcnc.org/38-general-linuxcnc-q...lved?start=80#188377
Last edit: 01 May 2025 07:29 by Aciera.
The following user(s) said Thank You: Adam Maszynotwór
03 May 2025 05:13 - 06 May 2025 06:28 #327590 by andypugh
I don't think that counts mode _can_ work with a Boxford style of toolchanger as the number of steps lost when the motor stalls against the endstop is unknown.
It could be modified to work, but it might be easier to start from scratch as a single-sensor position-mode stepgen changer wasn't really considered when the component was written.
You could even consider doing all the control in the G-code subroutine:
1) Scale the stepgen so that a position shift of 1 is one pocket.
2) Connect motion.analog-in-00 to the stepgen.2.position-fb
3) Connect motion.analog-out-01 to the stepgen.2.posiiton-cmd
4) Connect the home sensor to motion.digital-in-02
(Actually, you can use any numberered analog/digital IO, you would probably use in, out and digital 00 in practice, but I made them different for clarity)
toolchange.ngc:
O<toolchange> SUB
O100 IF [#<_carousel_homed> EQ 0] ; Do we need to home?
M66 E0 L0 ; read current stepgen pos into #5399
M68 E1 Q[10 + #5399] ; set the carousel in motion, by more than the number of pockets past the current pos
M66 P2 L1 Q20 ; Wait for the home pin
O200 IF [#5399 LT 0]
(abort, home timeout)
O200 ENDIF ; end of timeout check
M66 E0 L0 ; read home pin pos into #5399
M68 E1 Q[#5399] ; goto home pin, might need an offset here
G4 P5 ; wait for stop
#<_carousel_homed> = 1 ; mark homing as done
O100 ENDIF ; end of homing
(Normal toolchange without homing)
#1 = #<_selected+pocket> - #<_current_pocket> ; calculate move distance
O300 IF [#1 LT 0] if moving to a lower number
#1 = [#1 + 8] ; for an 8-pocket changer
O300 ENDIF
M68 E1 Q[#1 + #5399] ; move the requisite number of pockets
G4 P10 ; Wait (should really wait-on-input on a stepgen-in-position signal)
M68 E1 Q[#1 + #5399 - 1] ; move back against the stop
G4 P2 ; wait to stall against the stop
M6 T<_selected_tool> G43 ; change the tool, set offsets
O<toolchange> ENDSUB ; Done
Last edit: 06 May 2025 06:28 by andypugh. Reason: Forgot to set the homing parameter
The following user(s) said Thank You: tommylight, Adam Maszynotwór
  • Adam Maszynotwór
  • Senior Member
  • Senior Member
03 May 2025 11:51 - 03 May 2025 11:52 #327609 by Adam Maszynotwór
Thank you for presenting other approaches to the subject. It allows me to better understand the general principle of operation of various concepts and HAL structures
I will test your suggestions (it will take me some time) and I will definitely describe it on the forum so that it will be helpful for other and so that they do not bother you with nonsense like me hehe :) )
Last edit: 03 May 2025 11:52 by Adam Maszynotwór.
Time to create page: 0.364 seconds
