Axis_Comp having no effect[SOLVED]
1 year 1 month ago - 1 year 3 weeks ago #334380 by CNC4Life
I'm trying to axis comp a machine with a Renishaw ML10 Interferometer. Unfortunately no matter what comp type or file formatting I can come up with I cannot get the system to take effect. The machine is repeating +/- .001mm on every step of the run.
I've been working on this for days and had no luck. I also can't get any feedback from HALSHOW that mentions it in effect or a component related to compensation. My understanding this a rolling backlash table to linuxcnc, hower the values never change. The man pages are extremely sparse, but strait forward. Name a file, stuff it with (Target)  (POS Move) (Neg Move) and select a type 0 or 1.
Please help! I offer cookies of all types.
Last edit: 1 year 3 weeks ago by CNC4Life.
1 year 1 month ago - 1 year 1 month ago #334381 by CNC4Life
Replied by CNC4Life on topic Axis_Comp having no effect
Also of note the units in the RTL File are um so .001mm. Pass 1 is -5 to -170 and Pass 2 is -170 to -5.
The .zip is a zipped .xls file.
Last edit: 1 year 1 month ago by CNC4Life.
1 year 1 month ago - 1 year 1 month ago #334383 by PCW
Replied by PCW on topic Axis_Comp having no effect
Just a guess, but I think your screw compensation table is backwards:
"Compensation files must start with the smallest nominal and be in ascending order to the largest value of nominals"
Last edit: 1 year 1 month ago by PCW. Reason: sp
1 year 1 month ago #334416 by andypugh
Replied by andypugh on topic Axis_Comp having no effect
If the comp table is backwards then the interpolator function will only ever read the first value, so you will get a fixed offset, and no apparent compensation.
1 year 1 month ago - 1 year 1 month ago #334582 by CNC4Life
I'm happy to say, I was just being dumb and -5  was lowest number in my head except it was negative so it was obviously the highest number.  I also spent a bit of time playing with spreadsheets and the raw RTL file and it was easy make a mistake shuffling data.
So, I wrote a python script to handle the process. (I haven't tested it with an axis going in the positive direction, it should work.)
  Renishaw_Laser10_with_LinuxCNC
I really hope it helps someone someday.  I've attached my results before and after.
1 year 1 month ago #334589 by scotth
Replied by scotth on topic Axis_Comp having no effect
Good to see you have comp working.
The raw error looks very linear, are you sure about your Exp coeff value?
Time to create page: 0.078 seconds
