Axis_Comp having no effect[SOLVED]
- CNC4Life
04 Sep 2025 00:36 - 08 Oct 2025 14:02 #334380
by CNC4Life
Axis_Comp having no effect[SOLVED] was created by CNC4Life
I'm trying to axis comp a machine with a Renishaw ML10 Interferometer. Unfortunately no matter what comp type or file formatting I can come up with I cannot get the system to take effect. The machine is repeating +/- .001mm on every step of the run.
I've been working on this for days and had no luck. I also can't get any feedback from HALSHOW that mentions it in effect or a component related to compensation. My understanding this a rolling backlash table to linuxcnc, hower the values never change. The man pages are extremely sparse, but strait forward. Name a file, stuff it with (Target) (POS Move) (Neg Move) and select a type 0 or 1.
Please help! I offer cookies of all types.
Last edit: 08 Oct 2025 14:02 by CNC4Life.
- CNC4Life
04 Sep 2025 00:40 - 04 Sep 2025 00:41 #334381
by CNC4Life
Replied by CNC4Life on topic Axis_Comp having no effect
Last edit: 04 Sep 2025 00:41 by CNC4Life.
- Thank you received: 5330
04 Sep 2025 02:45 - 04 Sep 2025 17:00 #334383
Replied by PCW on topic Axis_Comp having no effect
Just a guess, but I think your screw compensation table is backwards:
"Compensation files must start with the smallest nominal and be in ascending order to the largest value of nominals"
Last edit: 04 Sep 2025 17:00 by PCW. Reason: sp
04 Sep 2025 16:43 #334416
Replied by andypugh on topic Axis_Comp having no effect
If the comp table is backwards then the interpolator function will only ever read the first value, so you will get a fixed offset, and no apparent compensation.
- CNC4Life
07 Sep 2025 17:44 - 07 Sep 2025 17:51 #334582
by CNC4Life
I'm happy to say, I was just being dumb and -5 was lowest number in my head except it was negative so it was obviously the highest number. I also spent a bit of time playing with spreadsheets and the raw RTL file and it was easy make a mistake shuffling data.
So, I wrote a python script to handle the process. (I haven't tested it with an axis going in the positive direction, it should work.)
Renishaw_Laser10_with_LinuxCNC
I really hope it helps someone someday. I've attached my results before and after.
Last edit: 07 Sep 2025 17:51 by CNC4Life.
- scotth
- Thank you received: 62
07 Sep 2025 20:04 #334589
by scotth
Replied by scotth on topic Axis_Comp having no effect
Good to see you have comp working.
The raw error looks very linear, are you sure about your Exp coeff value?
- CNC4Life
09 Sep 2025 00:45 #334664
by CNC4Life
Yes, it’s a rolled screw it has error from the manufacturing process. Thomson claims +\- 0.004 per ft / 300mm.
Though it could be mathed out in the SPU if I was using UCCNC or MASSO.
- scotth
09 Sep 2025 01:22 #334665
by scotth
I did most of my work on big iron. Watching what happens with an AC vent hitting the top of a machine with a laser will drive you crazy.
Good luck!
Good luck!
09 Sep 2025 14:49 #334705
Skunkworks implemented temperature compensation on his (large) mill a long time ago.Watching what happens with an AC vent hitting the top of a machine with a laser will drive you crazy.
- CNC4Life
08 Oct 2025 13:57 #336095
by CNC4Life
This is very cool, I have a customer who created cooling passages and plumbed a chiller into his spindle motor mount. Then ran it into spindle motor to keep it from growing.
Time to create page: 0.161 seconds
