Recompiling the motmod modules to expose pos-cmd pins
1 year 1 month ago #334815 by hellvetica
Hi, I'd like to control my robot arm directly using linuxcnc.
So far I've been using MDI and external offset pins to move the robot but I've had some issues with latency (mdi) and absolute positioning (external offsets). (When the robot starts, the motor's target position is not set to 0 but some other value close to 0 like 18 or -23 for some reason)
I'd like to pretty much hack the motion module so I can expose the pos-cmd pins that the trajectory planner sets so i can just connect to hal and set my cartesian position as I wish and not go in all these roundabout ways to get the robot to move.
The mini PC running the robot has a debian image with linuxcnc preinstalled.
1. What would be the easiest way to modify the source to achieve this?
2. How would I build the module and use it in my existing linuxcnc installation?
I'm not at all wary of digging into the C code, but I've never build linuxcnc myself.
Thanks for any tips :)
1 year 1 month ago #334823 by hellvetica
Thank you for the quick reply!
It's good that I can build a separate version without interfering with my base installation.
I'm having a hard time following the path of the position command through the code because of all the shared memory.
Could you give me advice on which module would be the best candidate to inject the extra pins into? Ideally it would be whatever the trajectory planner outputs its cartesian coordinates to. So instead of taking values from the trajectory planner it would take values from HAL pins.
1 year 1 month ago #334875 by hellvetica
I figured it out.
I created 2 pins:
pos_cmd_override and pos_cmd_override_enable
to emc/motion/axis.c as well as add the variables in the emcmot_axis_t and axis_hal_t structs.
Created getter functions like in the axis.c and the corresponding declaration in axis.h
Then in axis_calc_motion in axis.c i added
if (axis_get_pos_cmd_override_enable(axis_num)) {
axis->teleop_tp.pos_cmd = axis_get_pos_cmd_override(axis_num);
axis->teleop_tp.enable = 1;
axis->teleop_tp.max_vel = axis->vel_limit;
axis->teleop_tp.max_acc = axis->acc_limit;
Now I can set the pins to the desired robot position and the trajectory planner will do the rest. I can also use useful feedback pins like in-position which i couldn't do when using external offsets.
1 year 1 month ago #334887 by Aciera
glad you got it working. If you feel like sharing you could go to your cloned folder and post the output of:
git diff --minimal HEAD
Might help somebody in the future.
1 year 3 weeks ago #335867 by heaven
This method uses simple_tp in teleop mode, so it doesn’t synchronize velocity and acceleration. I’m trying to hack it to work in coordinate mode instead. that way, we’ll be able to control LinuxCNC by sending continuous waypoints through HAL pins.
I don’t fully understand how coordinate mode works yet; I just discovered where the calculations take place in the code:
github.com/LinuxCNC/linuxcnc/blob/master...tion/control.c#L1332
Time to create page: 0.054 seconds
