tpmod not loading on boot up with linux service
7 months 3 weeks ago #343938 by hellvetica
Hi, I'm currently running linuxcnc through a systemd service with linuxcncrsh as the fronted.
Usually it starts up fine and all the functionality is working as expected, but when the system first boots up and the service gets executed i get this from linuxcnc:
Mar 04 13:53:28 linuxcnc linuxcnc-delta[509]: LINUXCNC - 2.9.4 Mar 04 13:53:28 linuxcnc linuxcnc-delta[509]: Machine configuration directory is '/home/linuxcnc/LinuxCNC/DELTAEtherCAT' Mar 04 13:53:28 linuxcnc linuxcnc-delta[509]: Machine configuration file is 'DELTA_A.ini' Mar 04 13:53:28 linuxcnc linuxcnc-delta[509]: check_config: Unchecked: [KINS]KINEMATICS=rotarydeltakins Mar 04 13:53:28 linuxcnc linuxcnc-delta[509]: Starting LinuxCNC... Mar 04 13:53:28 linuxcnc linuxcnc-delta[509]: emc/iotask/ioControl.cc 786: can't load tool table. Mar 04 13:53:28 linuxcnc linuxcnc-delta[509]: linuxcnc TPMOD=tpmod HOMEMOD=homemod EMCMOT=motmod Mar 04 13:53:31 linuxcnc linuxcnc-delta[509]: Waiting for component 'tpmod' to become ready..Waited 3 seconds for master. giving up. Mar 04 13:53:31 linuxcnc linuxcnc-delta[509]: Note: Using POSIX realtime Mar 04 13:53:31 linuxcnc linuxcnc-delta[509]: Found file(REL): ./delta_ethercat_A.hal Mar 04 13:53:33 linuxcnc linuxcnc-delta[509]: Waiting for component 'lcec' to become ready.....
As I understand it the trajectory planner tpmod doesn't get loaded properly. What is unusual is that linuxcnc keeps running and seems functional but the robot exhibits very strange motion behavior. When i then check hal for loaded components tpmod is loaded and ready?
When i restart the service after this first boot it runs perfectly fine, it's only when i power cycle the machine that this error pops up.
Any ideas about what the cause might be?
Thank you!
7 months 3 weeks ago #343955 by andypugh
It sounds like, for whatever reason, tpmod isn't reporting "hal_ready()"
Though it seems odd in that case that LinuxCNC continues to load.
github.com/LinuxCNC/linuxcnc/blob/2.9/src/emc/tp/tpmod.c#L34
Time to create page: 0.095 seconds
