- Thank you received: 4
Carousel component with CIA402 controlled Ethercat closed loop stepper
7 months 3 days ago #344921
by TAKUYA
Hi everyone,
im currently trying to set up an 18 pocket carousel with a cia402 controlled ethercat stepper motor.
While I got it working in CSV (velocity mode), CSP so Positioning would be much nicer, faster and more accurate.
My issue with this however, is that I have no way (or at least none that i know) to regulate the speed when setting the target position over the counts-target pin. Am I missing something or is this just not possible?
How is the typical CIA402 driven drive speed regulated?
7 months 3 days ago - 7 months 3 days ago #344922
by hmnijp
Replied by hmnijp on topic Carousel component with CIA402 controlled Ethercat closed loop stepper
The speed is controlled by the trajectory planner. You can also use the limit3 or simple_tp components.
In your case - for the tool changer - you could use PP mode. Then the speed would be controlled by the drive itself, and you would only need to specify the new position. This mode is not available in the widely used cia402 component, but there have been examples of modifications on the forum, or a simple startup setting via SDO 0x6060=1 + a small amount of HAL logic
Last edit: 7 months 3 days ago by hmnijp.
The following user(s) said Thank You: TAKUYA
7 months 3 days ago #344923
by TAKUYA
Replied by TAKUYA on topic Carousel component with CIA402 controlled Ethercat closed loop stepper
Awesome Thank you.
ill try it with a simple limit2. Didnt know this component existed but it seems to do exactly what i need.
7 months 3 days ago #344925
by spumco
Following this as I've got a stepper-driven ATC using 'index' encoding under carousel.comp. I'm thinking about switching everything over to ethercat, but the ATC was a really fuzzy area for me.
Replied by spumco on topic Carousel component with CIA402 controlled Ethercat closed loop stepper
Awesome Thank you.
7 months 3 days ago #344931
by Hakan
Replied by Hakan on topic Carousel component with CIA402 controlled Ethercat closed loop stepper
Use PP (profile position) mode, not csp or csv. Unfortunately, the cia402 component doesn't support
that but it's not very hard to add.
5 months 4 days ago #346732
by spumco
Just checking back here - any progress or example of using an Ethercat drive with carousel.comp?
Time to create page: 0.231 seconds
