- Configuring LinuxCNC
- Advanced Configuration
- Carousel component with CIA402 controlled Ethercat closed loop stepper
- TAKUYA
- Thank you received: 4
29 Mar 2026 12:52 #344921
by TAKUYA
Carousel component with CIA402 controlled Ethercat closed loop stepper was created by TAKUYA
Hi everyone,
im currently trying to set up an 18 pocket carousel with a cia402 controlled ethercat stepper motor.
While I got it working in CSV (velocity mode), CSP so Positioning would be much nicer, faster and more accurate.
My issue with this however, is that I have no way (or at least none that i know) to regulate the speed when setting the target position over the counts-target pin. Am I missing something or is this just not possible?
How is the typical CIA402 driven drive speed regulated?
- hmnijp
- Thank you received: 49
29 Mar 2026 13:29 - 29 Mar 2026 13:31 #344922
by hmnijp
Replied by hmnijp on topic Carousel component with CIA402 controlled Ethercat closed loop stepper
The speed is controlled by the trajectory planner. You can also use the limit3 or simple_tp components.
In your case - for the tool changer - you could use PP mode. Then the speed would be controlled by the drive itself, and you would only need to specify the new position. This mode is not available in the widely used cia402 component, but there have been examples of modifications on the forum, or a simple startup setting via SDO 0x6060=1 + a small amount of HAL logic
Last edit: 29 Mar 2026 13:31 by hmnijp.
The following user(s) said Thank You: TAKUYA
- TAKUYA
29 Mar 2026 13:30 #344923
by TAKUYA
Replied by TAKUYA on topic Carousel component with CIA402 controlled Ethercat closed loop stepper
Awesome Thank you.
ill try it with a simple limit2. Didnt know this component existed but it seems to do exactly what i need.
- spumco
- Thank you received: 905
29 Mar 2026 14:15 #344925
by spumco
Following this as I've got a stepper-driven ATC using 'index' encoding under carousel.comp. I'm thinking about switching everything over to ethercat, but the ATC was a really fuzzy area for me.
Replied by spumco on topic Carousel component with CIA402 controlled Ethercat closed loop stepper
Awesome Thank you.
- Hakan
- Thank you received: 479
29 Mar 2026 16:34 #344931
by Hakan
Replied by Hakan on topic Carousel component with CIA402 controlled Ethercat closed loop stepper
Use PP (profile position) mode, not csp or csv. Unfortunately, the cia402 component doesn't support
that but it's not very hard to add.
- spumco
29 May 2026 07:23 #346732
by spumco
Just checking back here - any progress or example of using an Ethercat drive with carousel.comp?
- Will_cnc
03 Jun 2026 04:29 #346869
by Will_cnc
Replied by Will_cnc on topic Carousel component with CIA402 controlled Ethercat closed loop stepper
Please let me know if you make any progress , I am planning on using two cia 402 motors for the tool changer but don't know where to begin.
- spumco
03 Jun 2026 09:24 #346873
by spumco
I don't know about homing yet, but I don't think it's possible to get around the requirement to rotate the carousel until the index pin is triggered.
I threw the problem at ChatGPT and got a promising response. I've not had time to really work on it and test, but the AI Overlord suggests that carousel should be in counts mode, and connecting carousel.N.counts-target to the lcec.N.something-something-position-command is the basic connection.Please let me know if you make any progress , I am planning on using two cia 402 motors for the tool changer but don't know where to begin.
Time to create page: 0.304 seconds
