- Configuring LinuxCNC
- Advanced Configuration
- Help needed: Software setup for 4-axis tangential stone cutter (Mesa)
- souh-hil
27 Aug 2026 20:05 - 27 Aug 2026 20:08 #349060
by souh-hil
Help needed: Software setup for 4-axis tangential stone cutter (Mesa) was created by souh-hil
Hi everyone,
I’m building a 4-axis CNC machine to cut marble and granite slabs. It uses a large vertical diamond disk, and the A-axis swivels the blade to follow the cut direction . I’m using a Mesa 7i92 for the control.
I’ve built several plasma tables before, so I can completely handle the mechanical and electrical sides of this build. However, I have no idea about the software side of it. I’ve always just relied on the Pncconf wizard and have never manually edited HAL or INI files.
Could someone point me in the right direction for the software setup? Specifically:
- How to configure LinuxCNC " A-axis that automatically follows the X/Y path"
- How to set up the CAM software so the cut is perfectly to size without the top of the blade overcutting the part.
Any examples, component recommendations, or guides would be hugely appreciated. Thanks in advance!
Last edit: 27 Aug 2026 20:08 by souh-hil.
- Thank you received: 7478
27 Aug 2026 21:02 #349065
Replied by tommylight on topic Help needed: Software setup for 4-axis tangential stone cutter (Mesa)
1 No.
2 No. but...
If i understand correctly, it is a bridge type CNC that turns the head where the circular saw is mounted, so that strictly implies no A axis moves while the head is down into material.
Basically, it can not cut curves or rounded corners.
It should be easier to just use a text editor and do gcode manually, or if you have repeatable dimensions, do a VCP panel with a choice of cuts preprogrammed.
Also strictly requires interlocks to prevent anything (auto, manual, MDI) to turn the head if the head is under a certain value where the material can be, those saws cost a lot, and forcibly stopping such big motors is never healthy as you have about 2-15 seconds before it permanently retires. With smoke.
2 No. but...
- souh-hil
27 Aug 2026 22:46 #349066
by souh-hil
Replied by souh-hil on topic Help needed: Software setup for 4-axis tangential stone cutter (Mesa)
Thank you for the response. I have an idea, but it is difficult for me to make it a reality.I thought that if the A-axis rotates very slowly, we could use it to cut the outside corners of almost any shape. My main problem, however, was cutting inside corners, for example, on an L-shaped countertop. For that reason, I wanted to use a bit to cut the inside corners and rounded parts.Let me try to explain my idea.The blade will be in the same plane as the Z-axis. The assembly will also have a bit mounted near the tip of the motor or spindle. The entire assembly will rotate so that the bit can become perpendicular to the slab, while the diamond disk becomes parallel to the slab.Both tools will be mounted on the same motor or spindle. The rotating assembly will not be considered another machining axis. Instead, I would treat it as a tool-changing mechanism:
- Tool 1: Diamond disk for straight cuts
- Tool 2: 45-degree diamond disk for bevels and angled cuts
- Tool 3: Milling bit for inside corners and rounded parts
28 Aug 2026 03:09 #349067
That is a nice idea, till physics stick their nose into it and ruin everything!
The saw will spin at probably 1500-2500RPM (based on size maybe slower), and that is way to low for any end mill for hard stones, usually diamond coated.
Having said that, it will work, but it will be very, very slow.
Also, another advice that comes to mind, everything should be cut from the back side as the saw will eat into the part to make the cuts, so they remain on the back and not visible.
This will greatly depend on the material thickness, though, so that should be also taken into account.
- timo
- Thank you received: 61
28 Aug 2026 05:06 - 28 Aug 2026 05:15 #349070
by timo
Replied by timo on topic Help needed: Software setup for 4-axis tangential stone cutter (Mesa)
It seems a bit odd. I am reasonably sure that you cannot tilt the blade during the cut.
How much do those blades wander when you engage asymmetrical?
I have no idea, but I would be skeptical if outside contours are doable.
I saw that one in the Interweb.stylecnc.com/stone-carving-machine/4+1-automatic-stone-cnc-bridge-saw.html
For the price I would probably just buy it
if not a hobby project.
The rpm problematic on said machine is obviously solved by using two separate spindles. (one vertical) one 90° tilted that can rotate around a pivot.
For square cutouts it cannot be all to complicated to figure out how to manually program the thing.
.... I think I need a wood panel saw with router.....
How capable is a water jet machine?
How about a diamond coated steel rope? Seems there are options for that as well. The plate is vertical and the machines run around like one of those hot wire foam cutters.
Last edit: 28 Aug 2026 05:15 by timo.
- Thank you received: 4149
28 Aug 2026 05:21 #349071
Replied by rodw on topic Help needed: Software setup for 4-axis tangential stone cutter (Mesa)
Master branch solves the A Axis alignment because I added some new motion.interp.* pins to it. One of them is motion.interp.heading which is the tangential heading or direction in real time. Look for motion interpreter Metadata Pins in this documentation link
linuxcnc.org/docs/devel/html/en/man/man9/motion.9.html
I had envisaged there would be a companion component that dealt with knife alignment probably with external offsets with a setting that paused motion and lifted the knife if the next segment changed more than a certain angle (0 degrees in the case of the saw)
But I would look closely at FreeCAD CAM because one of their CAM developers Brad Collette (aka Siptronic) has done a bit of work with CAM for tangential cutters.There might be a ready made CAM solution.
The following user(s) said Thank You: timo
- souh-hil
28 Aug 2026 10:16 #349075
by souh-hil
Thank you Tommylight, Timo and Rodw for the replies and ideas.I live in Algeria, so buying a commercial stone CNC is very expensive for me. That's why I'm trying to build one myself.I've built several plasma CNCs before, but I always used PNCconf. I don't really know HAL/INI manually, so I'm starting with the 4-axis configuration generated by PNCconf.For now, my goal is actually simple: cut slabs accurately. For an inside corner, such as an L-shaped countertop, I'm happy for the saw to stop before it overcuts the corner. I can finish that part with another tool later.The machine will cut from the top/front side of the slab.For the A-axis, my idea is simply:raise Z → rotate A to the next cut direction → lower Z → cut → raise Z → repeat.I understand that A should not rotate while the blade is in the material, and I will use an interlock for that.Rodw, your mention of . Could you explain how I could implement it starting from a normal PNCconf-generated 4-axis HAL/INI configuration?
For now, I want to make the machine as simple as possible and just get it operational. Once I have it working and cutting slabs reliably, I can improve it and make it more efficient step by step.Thanks again everyone. I'm trying to keep the first version simple and build from there.
motion.interp.headingFor now, I want to make the machine as simple as possible and just get it operational. Once I have it working and cutting slabs reliably, I can improve it and make it more efficient step by step.Thanks again everyone. I'm trying to keep the first version simple and build from there.
28 Aug 2026 13:30 #349077
That is up to the users to find a use for it. The motion.interp.heading will be the exact direction of your saw blade is pointing as commanded by the gcode interpreter updated in real time. It may not be useful with a saw. But in the case of a tangential knife, it could be coupled to the A axis rotary angle so the knife always remained tangential to the direction of travel on G1, G2,G3 moves. I thought the machine would use a component to monitor the heading and do things like stop to lift and reposition the knife when transitioning from G1 to G2/G3 if the change in direction exceeded a safe limit. In your case that would be 0 degrees.
28 Aug 2026 13:46 #349078
Unless there is something fundamental that i am missing, you can not turn the saw while cutting, never ever, so "motion.interp.heading" can not be used, so why Rod?
28 Aug 2026 22:03 #349098
Exactly, why I said "In your case that would be 0 degrees."Unless there is something fundamental that i am missing, you can not turn the saw while cutting, never ever, so "motion.interp.heading" can not be used, so why Rod?
Time to create page: 0.290 seconds
