Closed Loop Servo System Recommendations
- calebn1844
13 Nov 2014 11:21 - 13 Nov 2014 11:39 #53055
by calebn1844
Closed Loop Servo System Recommendations was created by calebn1844
I am wanting to switch from a stepper motor system to a closed loop AC servo system with linear encoders on my bench top Dyna mill. Before buying components I would like to know what interface boards, amplifiers, servos and encoders work well together and with Linuxcnc.
Last edit: 13 Nov 2014 11:39 by calebn1844.
- jmelson
- Thank you received: 157
28 Apr 2015 22:12 #58187
by jmelson
Well, please excuse me tooting my horn, but the Pico Systems PWM controller and brushless PWM servo amps work quite well with LinuxCNC. We have controlled everything from tiny Pittman motors up to 40 Lb. Fanuc motors with this system. Depending on the specific linear encoders, they can have low-resolution analog output that requires interpolators, or excellent high-resolution digital-output encoders. So, you want to check the characteristics of your encoders before making any decisions.
Jon
Replied by jmelson on topic Closed Loop Servo System Recommendations
Geez, nobody ever answered this?I am wanting to switch from a stepper motor system to a closed loop AC servo system with linear encoders on my bench top Dyna mill. Before buying components I would like to know what interface boards, amplifiers, servos and encoders work well together and with Linuxcnc.
Jon
Moderators: piasdom
Time to create page: 0.082 seconds
