- drimaropoylos
- Thank you received: 39
21 Nov 2017 13:45 #102134
by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
Lol
- drimaropoylos
21 Nov 2017 13:51 #102135
by drimaropoylos
The only source i have found for ball bearing grade balls sells 1000 balls minimum, and if the balls are not standard (oversized), then 15000 is the minimum order. Any help appreciated here.
- Thank you received: 5121
21 Nov 2017 14:13 #102136
Replied by PCW on topic Retrofitting a 1986 Maho MH400E
- drimaropoylos
21 Nov 2017 14:18 #102137
by drimaropoylos
Thank you
- Thank you received: 4586
21 Nov 2017 15:03 #102138
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
- drimaropoylos
21 Nov 2017 15:13 #102139
by drimaropoylos
Thank you for that, the size is 3,5 mm. like those
www.amazon.com/Diameter-Chrome-Steel-Bea...mm+Bearing+Balls+G10
21 Nov 2017 15:17 #102140
For a ballscrew you want to be more accurate than just "3.5"
The vendor in the link I sent does them in .001" increments, but only around a 1/8" nominal size.
www.amazon.com/s/ref=nb_sb_noss?url=sear...+Screw+Balls+100+pcs
21 Nov 2017 15:52 #102141
More than that I think its suggested that the balls be in alternate sizes (spacer balls and load bearing balls)
21 Nov 2017 16:05 #102142
I think that alternating might be done also when fitting oversize balls in order to keep the train length the same.
- drimaropoylos
21 Nov 2017 16:25 #102144
by drimaropoylos
The micrometer reeds 3,499. The only solution is to send samples to the supplier and he will responsible to proper measure the balls with the his advanced measurement tools, and then send me the proper sized replacements. Or even better solution is to find some company on Europe to send the whole ballscrew, to replace all the balls and seals. The only one that I have found has never answer back.
Moderators: piasdom
Time to create page: 0.175 seconds
