- RotarySMP
- Thank you received: 563
26 Oct 2018 19:48 #119482
by RotarySMP
- RotarySMP
28 Oct 2018 15:30 - 29 Oct 2018 09:16 #119555
by RotarySMP
PID tuning Z went smoothly, once I relearned the use of the HALOscilloscope. The Z reference mark of the Heidenhain is at the bottom of travel and it's set up worked first time.
So it was time to crank it up and and make some chips...
Way cool machine, if a little scary for someone who has only ever used smaller machines. It sure blasts chips everywhere, so I'll need to get some replacement X waycover bellows, and install the housing before I do any serious work with it.
There is still a fair bit of work to do, to finish wiring the user control module and get all the buttons and knobs working.
Mark
Mark
Last edit: 29 Oct 2018 09:16 by RotarySMP.
- tecno
- Thank you received: 127
28 Oct 2018 15:54 - 28 Oct 2018 15:55 #119556
by tecno
Replied by tecno on topic Retrofitting a 1986 Maho MH400E
Nice work, I know the feeling doing the first cut.
Last edit: 28 Oct 2018 15:55 by tecno.
- RotarySMP
28 Oct 2018 17:52 #119559
by RotarySMP
Yep. Air punches
- Thank you received: 4586
28 Oct 2018 18:02 #119560
It's a little-known fact that corrugated cardboard way-covers were a factory option
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
I'll need to get some replacement X waycover bellows, and install the haousing before I do any serious work with it.
- RotarySMP
28 Oct 2018 18:45 - 28 Oct 2018 18:46 #119561
by RotarySMP
I'll sell this lightly used set on Ebay for a massive profit.
Last edit: 28 Oct 2018 18:46 by RotarySMP.
- drimaropoylos
- Thank you received: 39
30 Oct 2018 06:35 - 30 Oct 2018 06:38 #119635
by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
Last edit: 30 Oct 2018 06:38 by drimaropoylos.
- RotarySMP
03 Nov 2018 20:35 #119880
by RotarySMP
Sort of, yes, but I don't want to know what it feels like to be an australian
- Bernd
10 Nov 2018 09:46 #120377
by Bernd
Replied by Bernd on topic Retrofitting a 1986 Maho MH400E
Hi Mark,
what are your final PID-Values after tuning the axis?
I followed the tutorial gnipsel.com/linuxcnc/tuning/servo.html but don't get the following down without oscilation (P at a max. Value of 4,5). I can also change FF1 in every direction, i got no change of behavior. i can do what i want, i have always a following error of about 0,3mm with 500mm/min.
Bernd
Bernd
- RotarySMP
10 Nov 2018 13:20 #120385
by RotarySMP
Hello Bernd. Here is what I have at present. I am not completely happy with the Y axis. I had to limit its top speed a little as it starts oscillating at higher speeds and occasionally would trigger a following error. I played around a lot with various P, FF1 and FF2 settings, but do not yet have anything better than the following. I and D values are 0:
| X | Y | Z
P | 6.5 | 5.5 | 7.5
FF1 |0.22 | 0.228 | 0.218
FF2 |0.0021 |0.0015| 0.002
Max | 45 | 40 | 45
Acc | 50 | 50 | 50
Please let me know what values you settle on.
I didn't get anything done on the MAHO recently, except welding and panel beating a hole I put through the in the corner of a rear splash guard, by leaving a spanner laying there during testing. Was a good lesson in keeping body parts out of harms way. It didn't struggle at all to insert a 19mm open ender through 2mm sheet steel.
When I got the machine, it was complete except for the LH splash guard door. Rene of CNC-Baumgartner.de must have parted out a 400E, as he advertised a LH splash guard on Ebay Kleinanzeigen (Germany's craiglist). So buying that saves me a bit of fabrication work.
Mark
| X | Y | Z
P | 6.5 | 5.5 | 7.5
Max | 45 | 40 | 45
Acc | 50 | 50 | 50
Mark
Moderators: piasdom
Time to create page: 0.363 seconds
