  • RotarySMP
  • RotarySMP's Avatar Topic Author
  • Platinum Member
  • Platinum Member
03 Oct 2017 20:42 #99847 by RotarySMP
the rest of the updated wiring diagrams...
03 Oct 2017 21:07 #99850 by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
It looks the same
This is what I have made so far
03 Oct 2017 21:32 #99858 by drimaropoylos
It is for 5i20-7i77 combination, tomorrow I will make one for 5i20-7i77-7i84 following the drawings.
You have purchased the 7i84 just for placing it close to relay board?
  • RotarySMP
  • Platinum Member
  • Platinum Member
03 Oct 2017 21:33 #99859 by RotarySMP
Hi John, that Spindle.S block in the MAHOmh600E.HAL. That is just the placeholder created by PNCconf isnt it? This block will be replaced with the block which calls the GEARCHANGE.CLP won't it?
Thanks for posting your HAL development. I still need to get stuck into that part of the build.
Mark.
03 Oct 2017 21:50 #99864 by drimaropoylos
Yes this is created by PNCconf, now I need to find a way to command in the hall the G80,G100,..G4000 according to the commanded speed and pause the program during the change. For this we need help from more skilled members in here.
04 Oct 2017 05:31 #99896 by drimaropoylos
“it looks the same”, I was toking about the cabinet
04 Oct 2017 05:51 - 04 Oct 2017 05:51 #99897 by drimaropoylos
Or we can remove the G80…G4000 and put a comparator in place on ladder that compares the commanded speed with a range of predetermine speeds for each of the gear.
Last edit: 04 Oct 2017 05:51 by drimaropoylos.
  • RotarySMP
  • Platinum Member
  • Platinum Member
04 Oct 2017 05:53 #99898 by RotarySMP
Yep, I got that. That finder relay I got is only about 5mm thick, so hopefully it and the PSU will fit on the end of that DIN rail.
Were you intending to only accept G Code with the discrete spindle speeds the gearbox provides, or a HAL component which takes whatever spindle speed is commanded, finds the closest MAHO speed from a look up table and then engages that speed?
I have been wondering whether it might be a good idea down the road to add a VFD, to keep add spindle override potential while still keeping the gearbox active.
Mark
04 Oct 2017 06:03 #99899 by drimaropoylos
I have purchased a Mitsubishi FR-V540-3.7K-NA VECTOR INVERTER and I planning to keep only the back gear and middle gear on linux control and the input gear on the right position
04 Oct 2017 06:15 #99900 by drimaropoylos
The vfd will make possible rigid taping
Moderators: piasdom
