- Thank you received: 3885
30 Apr 2019 07:05 - 30 Apr 2019 07:09 #132331
Its never let me down and the batteries last forever. The correct part number for a Mesa config is ATWGP01-6BB-3.
That is a 5 volt compatible encoder with coded binary signals for the scale and axis selection switch to save pins. It can control 6 axes so there are a couple of extra MPG outputs. I was thinking of using one for reverse run...
The only thing I've found is that by default the estop is enabled so you need to switch it on or off or hit the estop on startup. I thin that is by design. I use estop_latch to merge the stop chain in HAL.
Replied by rodw on topic Retrofitting a 1986 Maho MH400E
That looks really nice. How reliable is the wireless connection?
Mark
Last edit: 30 Apr 2019 07:09 by rodw.
- pl7i92
- Thank you received: 358
30 Apr 2019 10:46 #132341
by pl7i92
Replied by pl7i92 on topic Retrofitting a 1986 Maho MH400E
- RotarySMP
- Thank you received: 563
30 Apr 2019 13:34 #132350
by RotarySMP
Doing things the hard way come naturally to me
- RotarySMP
30 Apr 2019 14:10 #132352
by RotarySMP
I am also very good at starting projects, and very patient at letting them mature.
I was given a tool holder with a broken off carbide jamming the hole.
Picked up some offcuts of an industrial plastic. (something harder but still insulative would be better)
Scrap endmills provide 6mm carbide shafting. These ones I bought as scrap, although I have a talent for produing scrap end mills.
Six balls from bearing
And a slug of Meehanite.
You can probably guess where this is going.
- pl7i92
30 Apr 2019 14:36 #132353
by pl7i92
i am pretty shure that there are Holders like you need
from older shops on low cost
most upgrde there stuff regular and sell the old stuff
- RotarySMP
30 Apr 2019 15:12 - 02 May 2019 08:16 #132356
by RotarySMP
Last edit: 02 May 2019 08:16 by RotarySMP.
- RotarySMP
02 May 2019 08:26 - 02 May 2019 08:27 #132496
by RotarySMP
Yesterday I felt more like turning than milling. Switched from the Meehanite to a 50CrMo4 drop I got from the scrappies. The finishing pass was a fresh TMCT090402 insert at 1800rpm, very shallow cut and low feed. The swarf came off as sparks, but it looks pretty.
Ground the mounting boss round on the SK40 tool holder, and then ground in an alignment goove using a cut off disc, before parting it by hand.
My grease press arrived so I filled it with Kluber NBU15 and lubed the angle gears of the MAHO.
I've been thinking about how unenjoyable engraving is at 16mm/min with the MAHO screaming away at 4000rpm. Decided to add yet another project, and ground up an old carbide endmill for a drag engraver bit, and then started making a holder for it.
Mark
Mark
Last edit: 02 May 2019 08:27 by RotarySMP.
- Thank you received: 4586
02 May 2019 12:16 - 02 May 2019 12:21 #132522
I keep looking at this:
www.ebay.co.uk/itm/New-Kollmorgen-KBM-43...-Motor-/323752695811
(1.2kW, 4750rpm) www.kollmorgen.com/en-us/products/catalo...-selection-guide-uk/
And only 36mm long: www.kollmorgen.com/sites/default/files/p...20%28KBM-43%29_0.pdf
It seems like it would fit nicely around a set of bearings and ER collet mounted in a 40-taper tool.
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
Last edit: 02 May 2019 12:21 by andypugh.
- RotarySMP
02 May 2019 14:16 #132538
by RotarySMP
A lot of work for only 750rpm more, and engraving wouldn't need 1.2kW, wouldn't it be better to go with the little frame size ten, and 20K rpm. You could probably fit the tool inside an ER 32 collet
I have an ER-16 collet chuck with 20mm shaft, and a set of P4 AC bearings stashed away in my future projects treasure trove, waiting to be turned into an engraving spindle. There wasa really good one made on CNCZone years ago, where the maker used the rotor and stator from a BLDC model motor as an itegrated motor/spindle. Not sure whether the is much of a benefit now that the chinese HF spindles are so cheap.
It looks like drag engraving works very well on aluminum. Probabaly can't do a useful depth on steel. At least I won't be thrashing the MAHO at full rpm for hour doing that.
Mark
Mark
02 May 2019 14:53 #132541
Yes, but there isn't one of those on eBay at the moment.
At 60mm dia the KBM(S)-10 is too fat to fit inside anything smaller than a 50 taper, but is fairly short so might still work.
Moderators: piasdom
Time to create page: 0.670 seconds
