Retrofitting a 1986 Maho MH400E
9 years 2 weeks ago - 9 years 2 weeks ago #100488 by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
So we press this button once (keep pressing) and the Linux outputs NC ready while the other contact enables the entire machine. Once we press again, the NC ready from the Linux goes off (209 is off) and the machine goes to estop condition. The same button activates and deactivates. Brilliant.
Last edit: 9 years 2 weeks ago by drimaropoylos.
9 years 1 week ago #100519 by RotarySMP
I just tried out that wiring on the MAHO. The Indramat ready relay 7A1 Bb1-Bb2 closes as soon as you switch on the cabinet main switch K1. I was a little surprised by that, but had missed the Phase L1 and L2 going into the Indramat with 1.5mm² wires to pins R and S directly, in addition to the big 6mm² wires going in through the E-Stop Relays. It is shown on drawing 04. So that start wiring we talked about should work fine.
However, I reinstalled the E-Stop buttons S1 and start button SH-1, but the SH-1 is not closing the E-Stop relays. so I couldn't test jumpering terminal 200 to 209. I need to figure out why that isn't working.
Mark
9 years 1 week ago - 9 years 1 week ago #100526 by drimaropoylos
you probably have removed the maho pendant, and the estop on it is not closing the circuit to activate the K1. So the circuit for 7K1, 7K2, 7K3 can’t activate.
Last edit: 9 years 1 week ago by drimaropoylos.
9 years 1 week ago #100527 by drimaropoylos
Good news for the 7A1 Bb1-Bb2
9 years 1 week ago #100529 by drimaropoylos
I now understand what the 7S1 switch is doing. When one terminal switch on an axis is triggered, the machine is disabled and the indramat can’t move the axis, but the L1 and L2 going into the Indramat with the 1.5mm² wires, gives the necessary power for the brake to release when the 7S1 is energized manually.
The following user(s) said Thank You: Crusader2050
9 years 1 week ago - 9 years 1 week ago #100536 by RotarySMP
drimaropoylos wrote: you probably have removed the maho pendant, and the estop on it is not closing the circuit to activate the K1. So the circuit for 7K1, 7K2, 7K3 can’t activate.
Thanks. Good call. I should have caught that, since I only just pulled that 19X5 terminal block a couple of days ago. Mine had no pendant, but that jumper was on the terminal block. Looks like I need a jumper between terminals 204 and 264 until I build a pendant.
Thanks also for the explanation of the 7S1 brake release circuit.
Mark
Last edit: 9 years 1 week ago by RotarySMP.
Moderators: piasdom
Time to create page: 0.182 seconds
