Will this Leadshine setup work?
29 Apr 2018 14:31 - 29 Apr 2018 14:32 #109804 by cupakm
Will this Leadshine setup work? was created by cupakm
Hi all,
I've expanded my PC with a parallel port as described here forum.linuxcnc.org/27-driver-boards/3439...l-cards-what-chipset and am wondering how can I find out whether the following Leadshine setup:
2x ES-M32320 Easy Servo Motor 2Nm - X and Y axes
1x ES-M32309 Easy Servo Motor 0,9Nm - Z axis
3x ES-D508 - easy servo driver 50V 8A - drivers
will work with a CNC IO Board by local (Czech) manufacturer cncshop.cz/PDF/CNC_IO_Board.pdf (connection sample on 3rd page)
They offer them together, so most probably it will. I went through all the manuals, but as I've never built similar machine, I'd rather ask first.
Another thing not yet clear to me is what LinuxCNC profile could I choose (or create) for that board.
They also offer a software tuning tool for the drivers as a free download, but its only an ugly windoze-exe, so no way. Isn't there a friendlier solution? I didn't manage to google anything yet.
Last edit: 29 Apr 2018 14:32 by cupakm.
  • Moderator
  • Moderator
29 Apr 2018 20:41 #109827 by tommylight
Replied by tommylight on topic Will this Leadshine setup work?
Yes it will and you have everything needed explained on both pdf's, the Czech one and the leadshine one.
If you do not understand Czech, i can help as i do speak Czech, but for the most part all you need is pictures.
Moderators: piasdom
Time to create page: 0.437 seconds
